Camber kit inquiry
Old Apr 18, 2006 | 10:45 AM
baggelis's Avatar
Default Camber kit inquiry
I am buying the tokico illumina shock and spring combo for my '91 CRX Si as well as the ST front and rear sway bars. I am aware that I will need a camber kit to have proper suspension geometry but I do not know which specific model I need, here are the options from an Ingalls online catalog:
3570 CRX 88-91 Front -34° to +1°
3572 CRX 88-91 Front +1.25° to 3°
3983 CRX 88-91 Rear +14° to +34°
3890 CRX 88-91Rear - 2°to +3°
Feedback is greatly appreciated
Old Apr 18, 2006 | 11:11 AM
EJ1 wilcox's Avatar
Default Re: Camber kit inquiry (baggelis)
You don't need a camber kit if your toe is set to zero.
I've been doing a lot of research on this and the conclusion is that camber doesn't kill tires, toe does.
Don't spend your money on a camber kit, just get an alignment and call it a day.
Old Apr 18, 2006 | 11:26 AM
baggelis's Avatar
Default Re: Camber kit inquiry (EJ1 wilcox)
So what is the point of camber kits? I thought that in order to maintain proper geometry when the car is lowered you need to adjust camber.
Arbiter
Suspension & Brakes
Nov 13, 2007 03:32 PM
jchrm80
Suspension & Brakes
Feb 17, 2007 10:16 AM
baggelis
Suspension & Brakes
Apr 19, 2006 08:41 AM
JustinHoMi
Suspension & Brakes
Feb 21, 2006 08:27 AM
k4ff1n3
Sep 7, 2002 01:00 PM
