97 accord obd ii communication problem
Old Apr 18, 2006 | 10:43 AM
darth458's Avatar
Default 97 accord obd ii communication problem
My daughters car cannot smog in NC because they demand communication with
obd ii. The dealer says that maybe she "hasn't driven the car enough" !! and because
of this they can't communicate with the computer??? Is there a quick fix for this
other than getting a new ECU? Do they know what they are talking about?
thanks!
-steve
Old Apr 18, 2006 | 10:51 AM
Ross 2.0's Avatar
In a Junkyard near you.
Something is wrong there. The connector is behind the ashtray in the console. If there were a communication problem the car more than likely would have other issues.
I think you need to take it to a different dealer. Someone doesn't know what they are talking about...
Old Apr 18, 2006 | 12:04 PM
darth458's Avatar
Default Re: (MooGoCow3)
Hi,
Well I couldn't make something like this up! She first heard it at a regular
garage. Then at a dealer.
-steve
Old Apr 20, 2006 | 11:51 PM
ricebike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> 95–97 Accord V6 & 96–97 Accord 4 Cyl.
If the malfunction indicator/Check Engine lamp remains lit or comes on while the engine is operating, the ECM has detected a malfunction and has stored a DTC in its memory.
To access the DTC memory using a scan tool, connect the Honda PGM Tester or an OBD II scan tool to the 16-pin DLC. The DLC is located in the center console behind the ashtray. Turn the ignition On and begin troubleshooting as indicated by the tester, following its prompts to diagnose the error. If unsure how to operate the scan tool or PGM tester, refer to the tool user’s manuals for specific operating instructions.
To access DTC memory using the MIL, connect the SCS service connector to the SCS check connector. The SCS 2 pin connector is located under the passengers side of the instrument panel. Place ignition switch in the On position begin MIL flash code diagnosis.
Data Link Connector (DLC) locations. 95-97 Accord V6 & 96-97 Accord 4 cyl. In Console.
Service check connector location. 95-97 Accord V6 & 96-97 Accord 4 cyl. Passenger side, up under glove box.</TD></TR></TABLE>
try autozone w/ their free obd II scan w/ the dlc
try the jumper / paper clip method and see if the check engine light would flash a code or 2 for u...
Old Apr 21, 2006 | 08:37 AM
JimBlake's Avatar
Default Re: (ricebike)
Busted wiring from ECU to the OBD-2 data plug??
On my '98 that plug is attached to a flimsy bracket, it sure looks easy to pull some wires out of the sockets. Especially if you're in a hurry working on someone else's car.
krbuser
May 16, 2019 12:50 PM
dave98
Oct 16, 2014 03:11 PM
boostedef123
May 31, 2011 11:26 AM
