Where can i get strut Mount Kit
I have a 98 accord ex 3.0 and im ready to put my eibach pro kit and my Kyb`s on the car where can i get the strut mount kit? THey did not come with the struts and my local parts store only has what looks like shock mounts? Repodevil@aol.com
98 Accords have front and rear struts.
You can re use the struts you already have if they are not worn out.
Front
Rear
Unless you are looking for #17/ 18 and that is already on your car and you re-use it
Front
Rear
why don't you just re-use the parts from your existing suspension to mount the KYBs? just disassemble the strut assembly when you remove it and use the parts you need.
AGX's call for a reuse of the old OEM top strut mounts. if you want an alternative, you could try sourcing some A'pexi (or similar...maybe omnipower?) pillow mounts. im sure those would be compatible with AGX's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teh FW »</TD></TR><TR><TD CLASS="quote">AGX's call for a reuse of the old OEM top strut mounts. if you want an alternative, you could try sourcing some A'pexi (or similar...maybe omnipower?) pillow mounts. im sure those would be compatible with AGX's</TD></TR></TABLE>
I am sure apexi top mount will not fit the spring, it's smaller in diameter
this is turning into a nightmare i just bought the kyb strut mount kits the rubber bushings and sleeves the ones for the rear will not fit so i returned them and got the kyb ones for the front i went to honda and got new plates all 4 and the kyb`s struts did not come with all the nutz so now im getting some tomorrow this has been very time consuming i hope i love the results...
CptHMCrunch
May 14, 2013 04:55 PM
