how to remove rear wiper assembly???
How do you guys remove the rear wiper assembly on a CRX? I took out the 3 bolts that mount the motor, but how do I dissassemble the wiper arm from the motor? Pls help????
Pretty easy.
To remove the wiper arm you remove the cover on the base of the wiper arm and remove the fastener with a ratchet. Then pull the arm off. Once you do that you can pull out the motor from the inside of the car.
acmoc
Apr 5, 2010 09:21 AM
9.3.S.I.L.U.D.E.
Apr 1, 2009 09:43 AM
FakeJDMEF8
Sep 26, 2004 07:39 PM
