ls lca and sway bar 96
my Q's is i have the complete rear disc conversion but i don't like how heavy it is, can i just use the lca and sway bar on my eg hatch and keep the drum setup. also if i sold it to my buddie with an eg coupe will he be able to install the rear disc brake with out the ls lca and sway bars and use his factory dx lca on the 96 ls rear disc brake converstion
You can use Integra LCAs and sway bar on your EG. You don't have to upgrade to rear disks. Yes, he will be able to use the rear disk setup on his coupe with the DX LCAs.
