Few random questions I could use some assistance with
Old Apr 17, 2006 | 07:31 PM
97AccordProject's Avatar
Default Few random questions I could use some assistance with
Alright, I"m trying to get a general idea of what I should be looking for in terms of regular maintence on my car.
I just rolled it over to 134K and change last week. And I had tuned it up and changed the oil. I'm going to have to replace the Spark Plug O-Rings because on Cylinders 2 and 3 I found puddles of oil when I removed the plugs and wires.
I'm wondering if it'd be a good idea to just have a Honda tech check the valves and then replace the valve cover gasket and plug o-rings?
And one last question, how many miles have people gotten out of a factory clutch under standard conditions? Because I'm getting the horrible feeling that my clutch is starting to slip at varying speeds...
Any insight I can get on this situation will be much appreciated. Thanks in advance.
Old Apr 17, 2006 | 07:42 PM
KP'92's Avatar
Default Re: Few random questions I could use some assistance with (97AccordProject)
I just recently purchases my 92 accord. It's got 151K on it and I adjusted the valves and replaced the valve cover gasket and seals. I would recommend doing this yourself. It's a pretty easy job as long as you have a feeler gauge. Sorry but I don't know anything about clutches.
Old Apr 17, 2006 | 07:48 PM
BLKFLSH's Avatar
The orings are under the rocker arm assembly. So it's not as easy as taking the valve cover off. It's a good idea to have them changed. The leak is not going to get better, only worse. There are many links for DIY on changing the orings, if you want to do it yourself. Oh, heres one. Below
http://www.cb7tuner.com/vbb/sh...seals
Old Apr 17, 2006 | 08:28 PM
Those are under the rocker arms? Ah crud... Well then I'm gonna just get those changed and the valves adjusted by someone who does that stuff for a living... I may be a mechanic, but I don't want to get into that involved of a project in my backyard.
Especially when the valve-train and disassembly of the upper cylinder head are involved...
Old Apr 18, 2006 | 08:56 AM
JimBlake's Avatar
Default Re: (97AccordProject)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97AccordProject &raquo;</TD></TR><TR><TD CLASS="quote">Those are under the rocker arms? Ah crud...</TD></TR></TABLE>There's round gaskets around each spark plug hole in the valve cover. Those are easy, just like replacing a valve cover gasket.
If that doesn't stop the leak, there's ALSO a set of O-rings down lower in the spark plug tubes. THOSE are the ones that require taking off the rocker assemblies.
zedjr
Jan 30, 2013 10:14 PM
EFz6er
Dec 11, 2007 05:29 AM
amir904
Aug 12, 2005 07:45 AM
tomisanoob
May 7, 2005 09:41 AM
rockwilda
Jun 9, 2003 09:52 AM
