di6a6 swap into 88 hf
Old Apr 17, 2006 | 05:41 PM
BrianRnold20's Avatar
Default di6a6 swap into 88 hf
if i do this swap, will i need a new harness? or will everything plug up? also would the stock hf tranny be good? or would an si be better?
Old Apr 17, 2006 | 05:45 PM
jlicrx's Avatar
Default Re: di6a6 swap into 88 hf (BrianRnold20)
make sure you use the HF harness - it will have a connector for the EGR valve that you won't need - it won't have a connector for the Fast Idle Control Valve if the A6 is 89-91 - you don't really need the FICV - get the Si transmission if you can
peiku
Feb 21, 2006 03:10 PM
fullraceacura
May 24, 2005 09:49 AM
wickedEFguy
Apr 8, 2004 02:08 PM
paulzy
Jun 21, 2003 03:34 AM
JCracer723
May 21, 2003 09:42 PM
