demintions and blueprints
well, i was talking to my dad. he is like a mechanic genius. if i can find the measurements of the motor mount conversion for the k20a swap in an 02 civic. so i guess i'm here asking if anybody can get or has the specs on those mounts. and also if anybody can get or has the blueprints for the wire harness conversion.
thanks
thanks
Its "dimensions"
What your asking for would probably be very well guarded secrets from the companies that make them...that why even from company to company the engine positions changes a bit. Some poeple just put the engine in with the mounts attached and create mount points on the car.
The Hasport mounts are $600, which is pricy but they did all the fitment work and the things are built like a tank.
i'm going to put the k20 in an 02 sedan.
so what your saying is ppl will use the k20 mounts and then just create the mount points on the car???
and please look past the spelling. i unfortunley came back to the states with alittle damage...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcivicex »</TD></TR><TR><TD CLASS="quote">i'm going to put the k20 in an 02 sedan.
Well I have seen poeple do that with putting H22's in old CRX's, since no one made mounts at the time.
komodomoe
May 13, 2013 08:11 PM
