Cracked Return line :(
Old Apr 17, 2006 | 04:02 PM
HamiltonRex's Avatar
Default Cracked Return line :(
My return line is cracked at the tank.. where the rubber line connects to the line that goes into the car.
I have the rubber line on about 3/4", the crack is about another 1" upwards.. Could i just clean the line, and slide the rubber line up furthur?
Thanks
Old Apr 17, 2006 | 04:05 PM
yellowrexsi's Avatar
Default Re: Cracked Return line :( (HamiltonRex)
should work, just make sure the clamp is tight. Check for leaks when you start it.
Old Apr 17, 2006 | 05:17 PM
Crx Jimmy's Avatar
yes you can do that, i had the same problem it rusted through. i just removed the rusty part and clamped to the good part farther up, you can use a longer rubber fuel hose for this as there is no real pressure in the line.
biglew
Dec 29, 2003 08:45 PM
jthelman
Sep 11, 2002 01:49 AM
