91 CRX Si with the 5 speed stock 1.6...
Old Apr 7, 2002 | 08:34 AM
TigerWoodsJr's Avatar
Default 91 CRX Si with the 5 speed stock 1.6...
is the stock 1.6 in the crx's worth even putting some money into for intake, exhaust, blah blah, etc? or should i just save for a b16?
Old Apr 7, 2002 | 10:39 AM
Redline130's Avatar
Default Re: 91 CRX Si with the 5 speed stock 1.6... (TigerWoodsJr)
Honestly, it's all up to you. Some would say to save your $$, and go get a B-series motor. While others may want to be different and build-up the SOHC 1.6L. I'm for the B16 or some other B-series motor.
Old Apr 7, 2002 | 10:48 AM
flat-blk-HB's Avatar
i am in to DOHC now but before all i was all about the SOHC...it makes you feel good to bust a DOHC *** with your SOHC...because you have usually have less money involved and are still faster...if you have the money a LS is a good swap but if mopney is kinda low then build up your SOHC..you can make a SOHC pretty damn quick!
Old Apr 7, 2002 | 04:08 PM
EF'n Fast's Avatar
Default Re: 91 CRX Si with the 5 speed stock 1.6... (89EF-BCUMBIE)
Get the intake and exhaust (60mm)...
then you can use 'em again after the dohc swap!
Old Apr 7, 2002 | 05:49 PM
Aahj's Avatar
Default Re: 91 CRX Si with the 5 speed stock 1.6... (EF'n Fast)
Well, if you are into autocross. You might want to think about keeping it stock. To start out, you will be more competitive in a stock class. This would be G-Stock. Then once you feel like you are ready for the next level, you can add an intake, headers, stand alone, etc.. This would put you in C-Street Prepared. Then if you decide to swap motors, this would then put you in Street Modified-2. You could actually be pretty competitive in this class mostly because it is fairly new and there aren't that many people in it.
good luck,
aj
Old Apr 7, 2002 | 08:48 PM
.ShawnD.'s Avatar
get rid of that rubber boot thats connected to your air box and it will sound like a intake and give it some what of a feel and then if your concerned about your muffler sound and like to hear your motor more then a crapy exhaust buy a thermal !! they have one of the most quite and profromance for your money!! esp. if you have vtec i did this when i first got my crx then i blew my motor so i swaped it out and got a b16a .. its well worth it !! except the vibration
dohdoh420
Feb 28, 2006 12:18 PM
ChaosUnbound
28
Sep 5, 2005 08:49 AM
JDMentality
122
Apr 22, 2005 08:13 AM
PlatinumGenes
22
Aug 13, 2002 08:12 PM
