WILL IT PASS INSPECTION IN MD???
Well guys, just baught me a used 90 civic si. I moved from Cali where I have a 03 si. Im pretty much moving here and since I have this car I have to get it inspected, you know... brakes, shocks, lights, etc....etc... THIS STATE IS SOOO STRICT!!!! Well my question is, without power steering and A/C will the car pass. I know without A/C it should but the guy I got it from took all this out too make it lighter and was planning on doing a swap but never got the chance to. What you guys say???..... WILL IT PASS??????
If everything else is in working condition, and you no longer have PS/air conditioning, then it will pass. Both the items are luxury items and are not nessecary to pass MD inspection. The plus is once you pass, you are straight for life, and emissions is nothing since if your car is too low, then you get a waiver, and don't have to do it. Let me know and I can help you pass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spiceisler »</TD></TR><TR><TD CLASS="quote">I need to pass the emissions. Can you help me out there?</TD></TR></TABLE>
Tell me your situation, and I can tell you your best options.
inspections in MD is a son of a bitch, i need to get mine inspected soon, but all i can find is way too much money.. i wish i could find an inspection for cheaper..
if you have coil overs you can slam it on the goround. then its to low to get on the tred mill. they will give you two years to come back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4doorcivic16 »</TD></TR><TR><TD CLASS="quote">if you have coil overs you can slam it on the goround. then its to low to get on the tred mill. they will give you two years to come back </TD></TR></TABLE>
That only works for emissions, and yes it works wonders(4years running for me
But goodluck and let us know.
)But goodluck and let us know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">
Before I turboed the car I failed Nox......unburnt fuel I guess, anyway, simple fix I installed a MSD 6200AL on my DOHC ZC went back and passed. The car still has the original cat, 1990 Si. I turboed the car now, single camY8-Z6/OBD1 chipped P28/Crome/2 1/2" Dp/ 4-wire 02 sensor, no MSD this time and yeah, failed for the same thing. For some reason the MSD does not work. I tried hooking it up to my new motor and it fried my dizzy. I'm going to change the cat take my chances and try again. The ref said that if I can show receipts for at least $400 in emissions related repair then I could get a waiver. I have an appt. in May.
</TD></TR></TABLE>Before I turboed the car I failed Nox......unburnt fuel I guess, anyway, simple fix I installed a MSD 6200AL on my DOHC ZC went back and passed. The car still has the original cat, 1990 Si. I turboed the car now, single camY8-Z6/OBD1 chipped P28/Crome/2 1/2" Dp/ 4-wire 02 sensor, no MSD this time and yeah, failed for the same thing. For some reason the MSD does not work. I tried hooking it up to my new motor and it fried my dizzy. I'm going to change the cat take my chances and try again. The ref said that if I can show receipts for at least $400 in emissions related repair then I could get a waiver. I have an appt. in May.
md inspections are a bitch. i just had to get my rex inspected (90 dx) and they failed it on the stupidest ****. i failed because at the time i had clear corners with amber bulbs (bullshit) and because my drivers seat was pretty torn up. they said it was "unsafe". whatever. it's the little things they like to get you on. my brother failed on windshield wipers. his car was running like **** at the time and kept stalling out, but they failed it for the wiper blades. i tend to think that in a real driving situation a car taht stalls every 5 min or so is more of a safety hazard, but according to md that's fine as long as everything else is in working order. the only nice thing about the md safety inspection is that you only have to do it once.
delslowhonda
May 2, 2006 10:52 PM
boredracer408
Jan 9, 2004 11:39 PM
