Those using Ganador Mirrors.......i need help getting the plug to work
Well Just got my mirrors painted and I just realized after I plugged them in that they dont work right. press up on the adjuster and the mirror goes left ROFL
Anyway.....I looked at it closer and the Ganador mirror has 4 prongs while the stock mirror only has three. So I would have to assume I need to get the plug from a stock mirror....cut and resolder the wire from the new mirror to the stock plug and then voila!
But I do however need to know which wires connect to which hole because the way they are right now is obviously wrong.
I know a few of you guys are running these mirrors and I would have to assume a couple of you got them working. So help me please!!!!!!
MOOFX i'm looking at u
Cwestindc2 help me out bro!
dont mean to thread jack
but where did you get your Ganador mirrors from
im debating on spoon or ganador... Ganadors getting the closer nod because they are power
I got them from a HT member for a steal of a deal. I just wish I could make these things work. I'll have some pictures in a second hhe.
You can probably trouble shoot this issue.
I was thinking that if you take some smaller gauge wire like 16 gauge...something easy to work with, you crimp some ends onto it and turn a few pieces into jumper cables. Plug one end into the car side of the wiring then the other end into the mirror. Try moving the mirror around and the wires around until you've reached what you have desired. Make a note, then swap wires in the harness accordingly.
Will that help?
Will that help?
b18's_only
Apr 15, 2009 12:36 PM
