couple b16 swap questions ( I searched)
Ok well these arent the usual questions 1. my vss on my b16 tranny has a very shallow spot for the speedo cable and the cable just sits in there, I even pulled it out when I filled my tranny with mtf and theres not even a spot for the clip, anyone else had this prob
2. for the green o2 sensor i just cut off my d15 plug and soldered the green plug onto the old d15 o2 wire and wired the brown plug to c8. Is the green o2 wired correctly?
As far as the VSS, i didn't use a clip for my cable and it works and stays in there. Its either c16 or c8 for the o2 sensor. When you search, just type in B16 problem, archived, and civic/crx forum....it will bring the correct answer to you....
bardo
Mar 10, 2004 05:36 PM
civictypenos
May 9, 2003 01:03 PM
