Toda spec A with ITR valve springs rev limit
Hi
i have a full stock b16a2, in a few weeks i'm planning to add:
Toda Spec A Camshafts
Toda Cam Pulleys
ITR Valve Springs
Spoon Headgasket (0.45mm)
Hondata Intake Manifold Gasket
I'd like to know your opinions about how high can i saffely rev the engine. For what value should i set the rev limiter. Please try to give real rpm values instead of tach values
Thanks for your time
Toda Cam Pulleys
ITR Valve Springs
I wouldnt cheat myself on ITR valvesprings with Toda A's. Better save now or dont buy the toda's at all, you mind as well upgrade the valvetrain to aftermarket products also if your getting a non stock camshaft!
-d.prom
-d.prom
You wanna be higher than stock because you think your parts are superior?
*shrug
change it to 8400.
8600 if you're ballsy.
Then again, I dont give a **** about your motor.
EDIT: <FONT COLOR="blue">The search button is on the top of every honda-tech page, it is bold and in </FONT><FONT COLOR="red">red</FONT>,<FONT COLOR="blue"> located the left side side of the screen. There, you have access to countless threads that have a lot of information, most likely the information you seek. We at honda-tech discourage making new threads on covered topics to save bandwidth. Thank you.</FONT>
*shrug
change it to 8400.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shibiku »</TD></TR><TR><TD CLASS="quote">what's the point of trying to rev to 8400 when ur springs can't take it :-P the first guy was right don't bother unless you buy the toda valvetrain!</TD></TR></TABLE>
itr cams have almost the same lift that the toda spec a 11.5mm vs 11.6mm and itr valvetrain can safely run till 8600 rpm (real value not tach value)
ricekiller1
Nov 27, 2007 11:25 PM
ricekiller1
Nov 27, 2007 03:18 PM
mrtrex
Jul 27, 2004 10:33 PM
powerfulperformance
May 5, 2002 05:16 PM
