about Skunk2 68mm Throttle body
just wonder anybody out there using Skunk2 TB??? i am using Skunk2 68mm TB found that end out loosing power also got some problems such as hard to start in the morning & the idle is not stable when i turn on the a/c, someone to me bcz the TB is too big so have not enough of pressure build up that's y end up loosing power is that true??? have anyone got the same problem as me???
looking forward hearing from u guys
cheers
cheers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by valentino08 »</TD></TR><TR><TD CLASS="quote">just wonder anybody out there using Skunk2 TB??? i am using Skunk2 68mm TB found that end out loosing power also got some problems such as hard to start in the morning & the idle is not stable when i turn on the a/c, someone to me bcz the TB is too big so have not enough of pressure build up that's y end up loosing power is that true??? have anyone got the same problem as me???
cheers
car?? motor?? = ?? <--- a little more info would be good, this should not happen on a C5 motor
cheers
</TD></TR></TABLE>car?? motor?? = ?? <--- a little more info would be good, this should not happen on a C5 motor
bootlegtrader
Oct 19, 2005 06:27 AM
631 Teggy
15
Mar 29, 2004 03:42 PM
