del sol - steering
Old Apr 16, 2006 | 11:06 PM
ThatsIt's Avatar
Default del sol - steering
i recently got a 96 delsol without powersteering, and when i drive the steering wheel pulls left or right depending on the level of the road im guessing, or at random times, which cause me to almost hit other cars and the curb. i was wondering if this is normal? i use to have an eg and never had this problem. i have 15x6 w/ azenis if that matter, also had the alignment done. can someone tell me whats wrong?
Old Apr 16, 2006 | 11:14 PM
saveacivic's Avatar
how low are you and do you have a camber kit?
Old Apr 16, 2006 | 11:17 PM
Stoich EG2's Avatar
Default Re: (saveacivic)
it's called being a man and holding your steering wheel where it needs to be
hahaha, im kidding, but that could be it
when you had your alignment done, was everything within spec?
it might be your tires + road. some tires like to follow the indentations of the road more than others
Old Apr 17, 2006 | 12:05 PM
jeff415finest's Avatar
yeah i am in a similar state right now..you gotta get used to it if you did your alignment and bigger wheels. im using stock 13s
Old Apr 17, 2006 | 01:52 PM
IHateJDM's Avatar
Default Re: (jeff415finest)
that happens with manual steering when driving on roads with grooves in the pavement. the wider your wheels, the worse it is. If its pulling on perfectly flat roads, its an alignment issue. If not, just man up and coutersteer when you need to, its not that bad.
Dezso3
Honda Civic (2006 - 2015)
Jul 23, 2015 01:19 PM
Fiero
11
Nov 18, 2007 08:06 AM
JDMgizmoDC2
Feb 20, 2002 05:54 PM
