1989 Honda Accord EX problem
Old Apr 16, 2006 | 09:02 PM
Albion's Avatar
Default 1989 Honda Accord EX problem
I have an 1989 Honda Ex carburated and on warm/hot days she will fast idle to around 2000 RPM while the clutch is in. Any suggestions on what may be the problem?correction for the problem? Any help would be appreciated Thanks.
Old Apr 17, 2006 | 08:26 AM
philadd's Avatar
Default Re: 1989 Honda Accord EX problem (Albion)
At first I was going to say that there wasn't an EX model for that year, but then I noticed you're in Canada. (I've never heard of a 3rd gen EX.) However, I'm still surprised that an EX model is carbureted. Anyway.
My first suspicion is a small tear or crack in a vacuum line, especially considering the age of the car.
Old Apr 17, 2006 | 03:52 PM
Albion's Avatar
Default Re: 1989 Honda Accord EX problem (philadd)
In canada the fuel injection version would have had a i behind the model ie lxi or exi. dx/lx/ex were all carburated. Thanks should i be checking by the carb for vacuum leak or is there a more prevalent spot to check...ie there is quite a few vacuum lines to check. Thanks for the help
Old Apr 17, 2006 | 03:59 PM
BLKFLSH's Avatar
I've heard you can spray carb. cleaner on the hoses, and when you hit the cracked hose you'll know it. Good luck
Old Apr 17, 2006 | 09:35 PM
philadd's Avatar
To be honest, it's been quite some time since I had my '88. I've forgotten the routing of the vacuum lines since then.
You may want to check out http://www.3geez.com. It's a site dedicated to 86-89 Accords. There will be more people over there that will be able to help, as most people on this site are only familiar with '90 and up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">I've heard you can spray carb. cleaner on the hoses, and when you hit the cracked hose you'll know it. Good luck</TD></TR></TABLE>
I've heard this too, but not until after I sold my '88. Go figure. It would have made things much easier for me than checking the 7349 vacuum lines one by one.
Old Apr 19, 2006 | 08:26 PM
Albion's Avatar
Thanks for all of the help and suggestions from the people on this site.
I will try your suggestions. Thanks again !
faran
Jul 14, 2013 09:00 PM
97skivic
Feb 17, 2008 10:21 AM
dlau420
Acura TL, RL & ZDX
Apr 3, 2004 08:51 PM
