Is it critical to grease axle splines before installing ??? (GSR)
Old Apr 16, 2006 | 05:58 PM
dave1234's Avatar
Default Is it critical to grease axle splines before installing ??? (GSR)
I just changed both my axles on my GSR, I greased bothe outboard splines, but didn't grease the inboard sides. I cleaned them well and put a very light coat of WD40 to clean, but wiped it off. Will this cause problems???? Should I take the axles back out and grease??? Any Help/Insight appreciated. Thank You!
Old Apr 16, 2006 | 06:40 PM
IN VTEC's Avatar
Default Re: Is it critical to grease axle splines before installing ??? (dave1234)
No need to bother. The inboard splines are lubricated by the transmission oil.
Old Apr 16, 2006 | 06:42 PM
dave1234's Avatar
Default Re: Is it critical to grease axle splines before installing ??? (IN VTEC)
What about the driver side splines where the intermediate shaft goes into the outer drive shaft???
Old Apr 16, 2006 | 07:00 PM
IN VTEC's Avatar
A little bit is fine just to help it slide down easier. A light coating of motor oil works just fine too if you don't want the grease all over the place.
slugo10
Mar 12, 2010 11:05 AM
ChinitodeNJ
Sep 9, 2009 12:12 AM
rdeezy78
May 8, 2009 01:47 AM
dave1234
Apr 16, 2006 11:14 PM
SikofFalln
Aug 7, 2003 02:05 PM
