Toda C + cam gear setting questions........
Old Apr 6, 2002 | 10:29 PM
Pinhead's Avatar
New User
Default Toda C + cam gear setting questions........
If I have Endyn 81.5mm high compressoin pistons and Toda C cams, stock gasket, and nothing off the head.....what's the most I can retard or advance the cam gears on either side???
PS I also have Skunk2 SS valves if that causes a problem..(normal size)
[Modified by Pinhead, 1:43 PM 4/7/2002]
Old Apr 7, 2002 | 09:37 AM
Pinhead's Avatar
New User
Default Re: Toda C + cam gear setting questions........ (Pinhead)
TTT
Old Apr 7, 2002 | 10:04 AM
Mike M's Avatar
Founding Member
Clay the Engine
Old Apr 7, 2002 | 10:08 AM
Pinhead's Avatar
New User
Default Re: Toda C + cam gear setting questions........ (TypeRmsm)
Ok? but there should be no clearance issues with cams at 0,0 right??
Where's sgT when you need him lol
[Modified by Pinhead, 2:09 PM 4/7/2002]
Old Apr 7, 2002 | 01:03 PM
AJ PwR's Avatar
Anything saids on the camgear.
Old Apr 7, 2002 | 01:05 PM
Pinhead's Avatar
New User
Default Re: Toda C + cam gear setting questions........ (AJ PwR)
explain....
Old Apr 7, 2002 | 02:28 PM
coquinn's Avatar
If you're not going to clay your engine, then leave them at 0,0.
That being said though ...why would you want adjustable camshaft gears if you're going to leave them at 0,0?
Moral of my post: Clay your engine.
Flux
Nov 27, 2007 03:42 PM
navin
Apr 19, 2006 09:22 AM
sheepey
Feb 27, 2006 06:58 PM
