Suspension & Brakes Theory, alignment, spring rates....
keeping lca with rear DA Sway Bar
Old Apr 16, 2006 | 01:23 PM
EvilPinkEye's Avatar
Default keeping lca with rear DA Sway Bar
like the title says, just got me a bar, and wounder if i can use the bar, similar to this set up in the pic where the kit has this bracket on the stock LCA bolted to the end of the bar.
anyone ever done this..can i just go to HOME DEPOT and find something close to this with out risking my butt??
Thanks
thanks jboy08 for the pic..
Old Apr 17, 2006 | 11:03 AM
HiProfile's Avatar
Default Re: keeping lca with rear DA Sway Bar (EvilPinkEye)
That picture is not dissimilar to stringing pearls...with dental floss. I got my LCA's for free, most people sell a set that has mounting holes for ~$30, bushings come to under $40 for them both. Brackets will be subjected to sever force, high probability you'd have to readjust/replace them frequently. AND you have to design them yourself.
That said, it looks like 4 U-bolts (square, not rounded), and maybe a thick plate connecting the upper bolts to mount the endlinks. Most hardware stores around here only have rounded u-bolts, not those types (more like wood saddle clamps).
Do it right, not half-assed like above.
Old Apr 18, 2006 | 10:42 AM
Default Re: keeping lca with rear DA Sway Bar (HiProfile)
true about the possible stress the brakets will get...well i know how much the arms go for with the holes, that i know. prob is if i where to mess with my stock arms, ill run into the dreaded seized bolt that we all love. i almost broke my bolts once and just decided to slide the coil-overs in by pulling the shock out, while still attached...
basically I'm not gonna mess with it until i get my new shocks when ever i get the chance to order them.
if it only weren't for the bolts
Coopa B18c5
Feb 1, 2013 09:39 PM
jaje
Oct 7, 2009 09:57 AM
JMelt4
18
Apr 30, 2007 07:43 PM
gwiffer
Mar 10, 2007 11:54 AM
Forrest Gump 9
Aug 4, 2004 09:30 PM
