oil leak coming from somewhere need help
posted this in the integ forum also.
okay im already changing all the gaskets and seals on my valve cover and getting a new cam seal. ? is that does it look like it could be leaking from somewhere else or just from the from cam seal?
this is under my distributor
and this is right under my vtec selinoid and where the cam seal which i'll be replacing
your thoughts on what else should be replaced
I guess it could all be from your cam seal. Not to many other places it could come from. Maybe that o-ring on the distributor is bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helloian. »</TD></TR><TR><TD CLASS="quote">definitely dizzy o-ring and cam seal
no biggie</TD></TR></TABLE>
^this was going to be my suggestion, looks like you covered all seals...good luck...let us know what you come up with....hope this solve you problem
no biggie</TD></TR></TABLE>^this was going to be my suggestion, looks like you covered all seals...good luck...let us know what you come up with....hope this solve you problem
eluder33
Apr 18, 2006 05:25 PM
