horrible gas mileage
98 civic dx. Horrible mileage. Back in the ricer days I put an adjustable fuel pressure regulator on. Its running at 50psi exactly. If I replace it with the stock regulator, think that will help??
At $3/gallon I cant afford to keep blowing through gas like this.
Well less fuel pressure should yeild less gas, so that is one option. Also, check you air filter, fuel filter and for possible dirty injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">what other modifications have u done to the car? cel?</TD></TR></TABLE>
This gets complicated so hang on....
intake/header/exhaust. O2 simulator. Car surges and bucks slightly when gas is held steady. No cel but the sim might be keeping that from happening.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheekdude »</TD></TR><TR><TD CLASS="quote">Also, check you air filter, fuel filter and for possible dirty injectors.</TD></TR></TABLE>
might also check your o2 sensor.
if you dont mind, how much mpg are you getting?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Tymer »</TD></TR><TR><TD CLASS="quote">might also check your o2 sensor.
if you dont mind, how much mpg are you getting?</TD></TR></TABLE>
Roughly 20mpg
Roughly 20mpg
I might be getting 100mpg, I might be getting 10. The fuel gauge is all over the place. I know to expect this on hard turns but even while driving on the hwy it goes from 1/2 to 1/4 to 1/2 to 1/8 and back to 1/2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGENT 99 »</TD></TR><TR><TD CLASS="quote">I might be getting 100mpg, I might be getting 10. The fuel gauge is all over the place. I know to expect this on hard turns but even while driving on the hwy it goes from 1/2 to 1/4 to 1/2 to 1/8 and back to 1/2. </TD></TR></TABLE>
omg mine is doing the same ****. its so annoying. i have same setup almost. i/h/e fpr crank pulley but i havent had a tune up in about a year and 6 months for an oil change. my gauge shows 1/4 tank and i still run out wtf. oh yea and i have 1 o2 sensor just hanging out somewhere in the engine bay b/c i dont have a 2 bung holes on my header (need to get that done) i would say the o2 sensor is hurting you a lil bit and tune up
oh yea and lower your pressure geez
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec »</TD></TR><TR><TD CLASS="quote">omg mine is doing the same ****. its so annoying. i have same setup almost. i/h/e fpr crank pulley but i havent had a tune up in about a year and 6 months for an oil change. my gauge shows 1/4 tank and i still run out wtf. oh yea and i have 1 o2 sensor just hanging out somewhere in the engine bay b/c i dont have a 2 bung holes on my header (need to get that done) i would say the o2 sensor is hurting you a lil bit and tune up
oh yea and lower your pressure geez</TD></TR></TABLE>
******* mother of Christ. I've been trying to reply for the last 15 minutes. Netowrk connection crashed and I threw my keyboard across the room causing my cpu case to jerk adn the coke on top to spill over causing my beagle to run and hide. I've cleaned it all up and restarting this ******* peice of **** computer and I think I'll be ok. I have a temper of Hell I've been told.
Anyway, what I was going to say you have no idea how much the same setup you have. I also have one sensor hanging because I dont have to holes. If you have a temper, we might be bros!
edit: hahaha, all that and you've logged off. :slits wrists:
edit: hahaha, all that and you've logged off. :slits wrists:</TD></TR></TABLE>
youre fucken weird
youre fucken weird
lol... w..t..f..
lol... w..t..f..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -DesTiNy- »</TD></TR><TR><TD CLASS="quote">
lol... w..t..f..
hhehe, well just but that sucker back to stock...O2 and pressure...check map like mentioned
lol... w..t..f..
</TD></TR></TABLE>hhehe, well just but that sucker back to stock...O2 and pressure...check map like mentioned
werd, my gas guage does the same thing
it'll be like full, 3/4, then down to almost a half, then back up to inbetween 3/4 and full
It's hard to know when
do I need to get a new guage cluster just for this?
One reason you're getting bad gas mileage is because you're running 50psi as opposed to the stock 40-42psi.
That O2 simulator makes the ECU is doing a good job of running the car by dumping too much fuel into the cylinders. I'll bet if you pulled your spark plugs they're probably black.
I'd put your stock fuel pressure regulator back on or turn your current one down to 40-42psi, as well as go out and buy a 5 dollar bung or a .39 nut that fits your O2 sensor and weld that ****** on there.
I agree with nota-eg. Go back to stock fuel pressure, get o2 bung and connect 02 sensor back, replace spark plugs, also check distributor cap, rotor, and also check timing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T »</TD></TR><TR><TD CLASS="quote">What should the stock fuel pressure be for a d16y8?</TD></TR></TABLE>
I believe it's around 40-42 base pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGENT 99 »</TD></TR><TR><TD CLASS="quote">98 civic dx. Horrible mileage. Back in the ricer days I put an adjustable fuel pressure regulator on. Its running at 50psi exactly. If I replace it with the stock regulator, think that will help??
At $3/gallon I cant afford to keep blowing through gas like this.</TD></TR></TABLE>
Yeah going back to stock regulator would help. Here is some more information to read over concerning your gas pump blues
http://www.discounttire.com/dt...s.dos
