Spoon Vtec controller
Old Apr 16, 2006 | 10:40 AM
turnsignalandy's Avatar
Default Spoon Vtec controller
I came acrros this part on the internet. Just wondring what exactly it does. Does it allow you to engage vtec at will?
Old Apr 16, 2006 | 11:07 AM
spoonracer84eg's Avatar
Default Re: Spoon Vtec controller (turnsignalandy)
You adjust what rpm the vtec engages. I have heard they arent worth the money. I had looked into getting one. Your better off just getting your ecu chipped if you want to change your vtec engagement.
Old Apr 16, 2006 | 11:17 AM
Default Re: Spoon Vtec controller (spoonracer84eg)
is it possible to engage vtec all the time? Will that expletive up my valvetrain? BTW I have a D16y8
Old Apr 16, 2006 | 11:19 AM
KoLRaNcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to engage vtec all the time?</TD></TR></TABLE>
Your car isn't going to go any faster, theres a reason why honda set it at certain rpms.
Old Apr 16, 2006 | 11:25 AM
Walterronny's Avatar
what your engine engage the vtec before dont means that it would be more fast.. you'll need to change the fuel map
Old Apr 16, 2006 | 11:28 AM
Default Re: (Walterronny)
oh ya that makes sense, cause if it engages at lower rpm but the right amount of fuel wont be there, ***** gona happen
Old Apr 16, 2006 | 01:26 PM
Default Re: (turnsignalandy)
yep and no you cant have vtec engaged all the time.
Old Apr 16, 2006 | 02:37 PM
schardbody's Avatar
i think everyone needs a lesson on what vtec actually is, its just like switching to a bigger cam at that certain rpm. and if you know anything you know that more lift at lower rpm equals less torque, the point of vtec is to keep the cam lobes small enough to produce low/midrange tq and then when those small lobes arent enough for the amount of air charge the ecu switches to the "high" cam lobes. if there were a better rpm for vtec to engage honda would have used it, they are for the most part optimized for from the factory: MPG, power, emmissions. no changes to the high cam lobe needed on a stock or mild motor.
Old Apr 16, 2006 | 03:02 PM
rodrez.'s Avatar
Default Re: (spoonracer84eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">yep and no you cant have vtec engaged all the time. </TD></TR></TABLE>
Yes you can, though it's not a good idea.
Old Apr 16, 2006 | 03:04 PM
professor poon's Avatar
I have that good simple "How VTEC Works" (and how to spell it without an H at the end) video. Where should I host it?
Old Apr 16, 2006 | 03:17 PM
jdmwannabe3's Avatar
Default Re: (professor poon)
what do u mean? where can u get that vtec video lol?
Old Apr 16, 2006 | 03:21 PM
schardbody's Avatar
same place that sells the vtec fluid
http://kalecoauto.com/index.ph..._id=6
Old Apr 16, 2006 | 05:23 PM
Default Re: (jdmwannabe3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmwannabe3 &raquo;</TD></TR><TR><TD CLASS="quote">what do u mean? where can u get that vtec video lol?</TD></TR></TABLE>
I could email it to u... PM me your email address and I'll send it to you
Old Apr 17, 2006 | 12:26 AM
my email address is teamdream1@hotmail.com
baseball_aj
Honda Civic (2001 - 2005)
11
Jul 26, 2007 07:09 AM
SixguN
14
Mar 11, 2005 11:45 PM
hcivic99
Aug 9, 2004 08:01 PM
JDM00SI
Jul 18, 2004 11:06 PM
Wazup
Aug 13, 2003 08:24 PM
