Eagle rods question?
Guest
Posts: n/a
Hey will eagle rods fit d16 1.6? any rods that fit right in d16 1.6? Im building up the motor with pistons and rods for turbo setup to handle 300hp. just wondering if eagle rods will fit right in d16 if not what rods would fit right in d16?
oh ok.. well it all depends on what rod you get, whats done to the motor internally, etc,etc.. go in the forced induction section, they will be able to help you out.. But make sure to read around, and search.. then post it up.. thats the best way to get an answer for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic0618 »</TD></TR><TR><TD CLASS="quote">yes they will be new, i was just asking if they would fit right in because i was reading some posts and people said they had to shave ? so that the rods would fit? this my first engine build up</TD></TR></TABLE>
this shaving was probably to make OEM pistons fit the aftermarket rods. Tell eagle what engine you have and they will get you the exact rod to fit your engine with no modification. Your just going to have to upgrades your pistons as well so you don't have to do any rigging.
eagle rods in a d series you will have to notch the block for the rods. the rods are wider then the stock ones, therefore you would have to notch the cylinders for clearance
Guest
Posts: n/a
o ok that clears that up i feel better now. I have a couple more questions. im going to get the head rebuilt, and going to get the block honed because i dont want to mess up on it. How much estimate cost to honed d16 block? Second question is Do you know any places? sites? that have a great step by step with rebuild? this is my first rebuild.. thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic0618 »</TD></TR><TR><TD CLASS="quote">Hey will eagle rods fit d16 1.6? any rods that fit right in d16 1.6? Im building up the motor with pistons and rods for turbo setup to handle 300hp. just wondering if eagle rods will fit right in d16 if not what rods would fit right in d16? </TD></TR></TABLE> God iw as hoping someone was going to say that..Any H beam style rod will require you to notch your block..Crower makes I-beam rods that will fit, but they're too expensive IMO and eagle's will do just fine. Go to turbod16.com there's a ton of people like myself that are doing or have done rebuilds. A honing job will only cost about 70 bucks, but youmight as well do a bore, hone, hottank AND a notch job while you're at it. http://www.terrytinney.com for your machining needs. Oh and if you do get eagles go to http://www.tunertoys.com and talk to craig. You'll need a turbod16 account, but he'll give you 10% off and they're like 318 shipped
