FS: NEED PARTS BARE BLOCK BUILDERS! EVERYTHING INSIDE!!!!
EVERYTHING IS OBD1 & OBD2
I HAVE PICS OF EVERYTHING JUST ASK!
-GSR upper tranny mount $ 20
-GSR upper timing gear cover *cut* $15
-GSR valve springs w/retainer *outer valve springs* $20
-99-00 Si driver seat $40
Ls/b20 Oil pan $20
Ls/b20 oil pump $25
Ls/b20 water pump $25
Ls/b20 belt tensioner w/ spring $10
Ls/b20 pulley $25
b20 pistons w/rods $40
b20 pistons w/o rods $20
ARP rod bolts w/nuts (6) $20
-99 b20z 84mm crank w/ main caps $60
-(2)b20b/z 84mm headgaskets used twice $35 a piece
-(8)b20 head studs $25
-b20b head w/cams (only valve train,all caps and cams)$60
-Brand new 90-93 DA Hi performance brake pads
made by NISSIN $30
-Brand new 4x100 POWER SLOTTED ROTORS (civic's/integra)
One is for the Left and is 9 1/2 $40
One is for the Right and is 10 1/2 $40
SHIPPING AT YOUR EXPENSE....I HAVE PICS OF EVERYTHING JUST ASK
Modified by Frank_2.0L at 2:26 PM 6/3/2006
Ls/b20 Oil pan $20
Ls/b20 oil pump $25
Ls/b20 pulley $25
made by NISSIN $30
