I got a question about my h22 pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_crx »</TD></TR><TR><TD CLASS="quote">I got a h22 its ready for turbo. On the bottom of the ross pistons its says 85M is that mean 85mm? </TD></TR></TABLE>
That's wired because that means you have a 85mm piston.on a H22.Was your block reslevved??? Call up Ross direct and find out, as far as I know the B-series pistons will work in a H22 as long as its reslevved for it.
9 out of 10 times that is just a reference number for the piston manufacturer. They use that 85 mm forging for a number of different sizes, 85 mm probably6 being the smallest! Look at the part number for the piston, and not the forging number!
