eibach springs sag
i have eibach sportline springs on my eg with 17's well my problem is that the back sits lower then the front and the tires rub the inside and out when i conner. so what i was hoping to find out is if there is somthing i can do to stiffin up the rear springs i.e. helper spring. please help me.
if that where the case the rear would be jacked up anyways. im guessing they are just sagging, get another spring rubber and put it in if you have access to a spring compressor, if not, i guess you need some new springs.
FIRST OFF I WOULD THINK ABOUT GOING DOWN TO A 16' OR EVEN 15' FOR BETTER PERFORMANCE. IF YOU DID THAT YOU SHOULDNT HAVE ANY PROBLEMS PLUS THEY LOOK REALLY GOOD ON EG'S. JUST SHAVE A LITTLE OFF AND LOSE SOME WEIGHT!
i bought the car with the 17's so i have been looking around for some si's or gsr wheels. i havae a system but its nothing to make the springs sag. i rolled the fenders and it helped. im going to try to put another spring rubber and give that a shot thanks.
