head swap
Old Apr 6, 2002 | 07:39 PM
maximedx's Avatar
Default head swap
can i put a d16a1 88-89 integra head on my d16a6 engine block.i think is possible because the two motor are d series engine.
Old Apr 6, 2002 | 07:43 PM
Redline130's Avatar
Default Re: head swap (maximedx)
No, the D16A1 is not compatible with the A6 or any other sohc D-series motor.
Old Apr 6, 2002 | 08:11 PM
maximedx's Avatar
Default Re: head swap (cyber13)
so what dohc head fit on my d16a6 block.
Old Apr 6, 2002 | 08:31 PM
Jeef's Avatar
none... to put it simply
Old Apr 6, 2002 | 08:32 PM
flat-blk-HB's Avatar
i dont think there is a DOHC head to swap to your block..you could go w/SOHC VTEC....(d16z)(d16y)...go gain in HP..
Old Apr 6, 2002 | 08:37 PM
Mugen Dom's Avatar
Default Re: head swap (89EF-BCUMBIE)
suposidly it will bolt on not to start a argument but it will the oil holes dont line up and such but it wll but the compression would suck and it wouldnt run right most likely.... get a d16z6 or y8 head for vtec and the y8 head will up ur compression ratio also
Old Apr 7, 2002 | 06:34 AM
jdstoledo's Avatar
Try this page
http://crx.honda-perf.org/articles/z6swap/z6swap.html
P.Raickovic
Mar 13, 2016 02:53 PM
C_R_X_V_T_E_C
Aug 6, 2006 12:05 PM
shrug
Apr 17, 2004 10:03 PM
