Is lighter flywheel actually better?
Old Apr 15, 2006 | 05:53 PM
jadugartir's Avatar
Default Is lighter flywheel actually better?
I am buying a new clutch and a figure might as well replace flywheel too while the tranny is off. anyways the kits on ebay are 269 for a exedy clutch and 7.4 lb fidanza flywheel, or 299 for a exedy clutch and exedy 9.5 lb flywheel. Id rather go with the cheaper since i know fidanza is a good brand, but im afraid 7.4 lbs is just TOO light for my setup. im running a b16a2, so im already lacking in low end. how is the lightened flywheel going to affect my car, and will 7.4 be way too light? My car is daily driven, occasionally ran hard, not a track car. any suggestions would be appreciated.
Old Apr 15, 2006 | 06:09 PM
-DesTiNy-'s Avatar
I'm a Jackass
it will take time to get used to... you will over rev all the time...
if you drive alot on the streets, it could be a lil annoying over reving the **** out of it! haha
Old Apr 15, 2006 | 06:11 PM
crazi_E's Avatar
Default Re: (-DesTiNy-)
^^ i conqer
Old Apr 15, 2006 | 06:23 PM
De_tour's Avatar
Default Re: (crazi_E)
i just know that you can break your motor if u dont have the crank setup for it.
Old Apr 15, 2006 | 08:33 PM
Syndacate's Avatar
NVM, sorry -- I don't really see a problem with it, like he said, u'll overrev until you get used ot it as it'll be a lot less for the crank to turn.....but I don't see a problem...again I could be wrong and overlooking something..
BMaDOHC
Oct 4, 2006 01:44 PM
90AccordVTEC
Oct 21, 2005 05:29 AM
Fresno_NSX
Mar 15, 2005 09:26 PM
97F22B2
Sep 23, 2003 12:25 AM
lozersk8er
Nov 9, 2001 06:45 PM
