Need help on EX/Si Tranny code...
Old Apr 15, 2006 | 05:48 PM
CO_CReX's Avatar
Default Need help on EX/Si Tranny code...
I currently own a 95 EG CX and Im doing a MINIME swap and while Im at it, I want to switch trannys because the CX gears are WAY to long.. LOL Im looking for what tranny code I would need for a EX/Si tranny. Any help? Thanks
Old Apr 15, 2006 | 06:07 PM
Luserkid's Avatar
Default Re: Need help on EX/Si Tranny code... (CO_CReX)
S20 B000 EX/SI tranny.
Old Apr 15, 2006 | 06:26 PM
dohcdelsol's Avatar
Default Re: Need help on EX/Si Tranny code... (Luserkid)
the b000 will be in a circle stamp near the filler plug at the top of the tranny
Old Apr 15, 2006 | 08:48 PM
93civicsedan's Avatar
Default Re: Need help on EX/Si Tranny code... (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">the b000 will be in a circle stamp near the filler plug at the top of the tranny</TD></TR></TABLE>
Do you have a pic of this? I cant find it on a tranny someone is selling me. Thanks.
Old Apr 15, 2006 | 09:41 PM
schardbody's Avatar
its actually P20/B000....... anyways, its right next to the fill plug. if you are looking at the tranny as it would sit in the car, its the side facing the passenger fender, about halfway up.
Old Apr 15, 2006 | 10:49 PM
zacatkings's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">its actually P20/B000....... anyways, its right next to the fill plug. if you are looking at the tranny as it would sit in the car, its the side facing the passenger fender, about halfway up.</TD></TR></TABLE>
your wrong s20
Old Apr 16, 2006 | 09:08 AM
schardbody's Avatar
its not S20, they are all P20, they say S20 on the serial tag, but thats not the casting number. i have 2 P20/A000 sitting here, and 1 P20/B000 next to me. but if you dont believe me oh well. keep looking for S20, you will see it on every sohc hydro tranny.
Old Apr 16, 2006 | 04:38 PM
I checked the tranny today but I dont see the stamp anywhere. Can someone post a pic? Thanks.
Old Apr 16, 2006 | 07:05 PM
schardbody's Avatar
its real small, cast into the housing, not a sticker or anything, if you cant find it your blind. its right next to the fill plug. the circle its in is only the size of a quarter. might have to clean it off to read it/see it.
Old Apr 16, 2006 | 08:37 PM
dohcdelsol's Avatar
its smaller then a quarter and can easily be covered up with grease/grime/dirt
take a can of brake clean and load up around the fill plug... wipe away and you'll see it
Old Apr 16, 2006 | 10:07 PM
Bense's Avatar
Default Re: (dohcdelsol)
s20 = 92-95
s40 = 96-00
a000 = small bearing case , s20 sticker, a000 case = cx/vx tranny or lx/dx tranny
b000 = big bearing case, s20 sticker, b000 case = ex/si tranny (si has 0.750 5th, ex has 0.702 5th
a000 s40 = hx/cx or dx/lx tranny
b000 s40 = ex tranny
Old Apr 16, 2006 | 10:14 PM
Bense's Avatar
Default Re: (Bense)
also, d16z6 del sol si from 93-95 had 0.750 5th gear and civic hatchback si from 92-95 had 0.750 5th gear
96-97 del sol si had a 0.702 5th just like the ex/dx/lx/vx/hx/cx/whatever
just checked the part numbers because I wasn't sure if obd2 d16y8 del sol si used the 0.702 or the 0.750 5th gear. I guess that means the 93-95 del sol is faster than the 96-97 in 5th gear!
Old Apr 17, 2006 | 12:51 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (zacatkings)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zacatkings &raquo;</TD></TR><TR><TD CLASS="quote">
your wrong s20 </TD></TR></TABLE>
Sorry sir, you are wrong...........
PL3 = 88-91
P20 = 92-95
P4A = 96-00
As in the link in my sig.......
Basic Info
You can tell a DX/CX/VX tranny from a EX/Si by numbers cast into the housing. Just above the filler plug is a set of numbers.
P20/A000 is for DX/CX/VX
P20/B000 is for EX/Si
Old Apr 18, 2006 | 05:07 PM
CO_CReX's Avatar
Ok guys, I need some more help... The guy I am trying to buy one of these trannys from has 3 trannys for sale and he grabbed all the numbers on them for me so I can be sure Im getting the right one. This is what he gave me...
s20-1025184
j8b p20 ( 5 speed tranny )
l3-2139362 (5 speed tranny)
l3-2300888 (5 speed tranny)
Are any of these an EX/SI tranny?
Old Apr 18, 2006 | 05:12 PM
Bense's Avatar
Default Re: (CO_CReX)
those numbers are worthless
Old Apr 18, 2006 | 05:14 PM
schardbody's Avatar
cant tell from them numbers, sounds like he is looking at the sticker not the numbers cast into the tranny case.
Old Apr 18, 2006 | 05:24 PM
CO_CReX's Avatar
Ok where exactly am I supposed to tell him to look?
Old Apr 18, 2006 | 05:30 PM
schardbody's Avatar
see mista bone's post w/ the pic w/ numbers/letters in it. thats it, right next to the fill plug on the side of the tranny.
Old Sep 11, 2006 | 11:02 AM
Kelly.'s Avatar
I've quit using this account
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CO_CReX &raquo;</TD></TR><TR><TD CLASS="quote">Ok where exactly am I supposed to tell him to look?</TD></TR></TABLE>
i have used this thread a few times to verify tranny codes,
si while i had a few trannys laying around my house (yes those kind ) i decided to take a few pics to help out.
im at works, so ms paint is all i have. deal with it
these are through photobucket, and i plan to leave them up.
hope this helps someone.
Old Sep 11, 2006 | 01:11 PM
4DRmafia's Avatar
how come my other tranny says p20/A00? it dont have the P20/A000 but only 2 00?
Old Sep 11, 2006 | 01:19 PM
Kelly.'s Avatar
Default Re: (SkipMic2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">how come my other tranny says p20/A00? it dont have the P20/A000 but only 2 00?</TD></TR></TABLE>
i give up, why?
p20/Axxx is a dx tranny.
Old Sep 11, 2006 | 01:22 PM
4DRmafia's Avatar
idk...it weird, when i saw this thread, i was likeoh cool good time to check my other tranny for my car, and next thing i know it says P20/A00 with only two 00 on it. this stumped me alot now....
Old Sep 11, 2006 | 01:23 PM
4DRmafia's Avatar
not a jdm tranny is it ?
Old Sep 11, 2006 | 01:26 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
well, that seems odd.... i just did a 99 civic ex tranny, and i pulled the original tranny out and it is a P4A/A000....
Old Sep 11, 2006 | 01:40 PM
Kelly.'s Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney &raquo;</TD></TR><TR><TD CLASS="quote">well, that seems odd.... i just did a 99 civic ex tranny, and i pulled the original tranny out and it is a P4A/A000.... </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">
PL3 = 88-91
P20 = 92-95
P4A = 96-00
Basic Info
maybe it wasnt the OG tranny?
