1990 Auto EX tranny question
Old Apr 15, 2006 | 04:49 PM
rleonekc's Avatar
Default 1990 Auto EX tranny question
Yeah im about to replace the tranny in my car, due to failure...
To do this am i gonna have to lift the motor out...????
Could someone help me with the process or somethin
Any help appriciated
Old Apr 15, 2006 | 06:06 PM
rleonekc's Avatar
Default Re: 1990 Auto EX tranny question (rleonekc)
Anyone
Old Apr 15, 2006 | 06:12 PM
BLKFLSH's Avatar
The best advise I can give you, is to find a Helm service manual for the car. It should have step by step instructions. Have fun
Old Apr 15, 2006 | 06:24 PM
johnwiltfongjr's Avatar
Default Re: 1990 Auto EX tranny question (BLKFLSH)
I am pulling the tranny out of my 92 LX this weekend and I am not pulling the motor. I am sure it would be 100 times easier with the motor out but I am getting it done leaving the motor in the car just the same....
Old Apr 15, 2006 | 06:26 PM
BLKFLSH's Avatar
Default Re: 1990 Auto EX tranny question (johnwiltfongjr)
It is possible, from what I've heard. Good luck
Old Apr 15, 2006 | 07:56 PM
Dmc1's Avatar
just pull trans I say. you should be able to drop it out the bottom no problem.
Be carefull an auto trans is a heavy ****.
Old Apr 15, 2006 | 08:10 PM
accord-pro's Avatar
no need to pull the motor or lift it up,,, tranny will come out easily,, i would also reccomend getting the HELM book , it will make the job easier..
you will need a few good jack stands, loosen the axle nuts while car is still on the ground. if you do not have any air tools and proper equipments .. it will be a long job .. make sure to drain the tranny ..
Old Apr 16, 2006 | 12:31 PM
rleonekc's Avatar
Default Re: 1990 Auto EX tranny question (accord-pro)
Am i gonna have put the car up on a lift? or is there another way
Old Apr 17, 2006 | 03:22 AM
you will have to jack the front end up and put a set of jack stands underneath for support and safety. Also, get a couple of decent 2x4's to support the engine and tranny when you are dropping it out the bottom.
_EF9
Transmission & Drivetrain
Mar 18, 2009 05:33 PM
carbonek9
Dec 13, 2006 09:50 AM
BigBank420
Feb 17, 2004 01:48 PM
JMD
Jul 22, 2003 08:46 PM
FG Two
Nov 26, 2002 10:35 PM
