crx with jdm dohc zc trouble!
i bought a jdm dohc zc swap and i put it in an 89 crx hf.. everything is wired up right and i have a pm7 ecu.. but all it does is turn over.. like it wants 2 start but its not firing.. iv rechecked my wiring and changed the ecu from a pgy 2 pm7 and the results are the same and im runnin out of ideas.. its getting gas and compression just no fire.. what do u guys think?
yea but the guys that put it in build racecars and they had 1 of their ppl rewire it.. so yea.. i was thinkin maybe the ignition coil but idk how 2 find 1 for that dizzy unless a usdm 1 would work
I had to turn mine over for about 5 minutes before it finally fired and roared to life, just that first time. i had no idea why, because after that initial start, it fired right up and has been doing so promptly for years now.
the injectors are good.. its getting gas but no fire 2 the spark plugs... like its not comin out ofthe dizzy.. i was thinkin ignition coil or something but im just trying 2 figure out... its gettin fuel and everything and it wants 2 start like amofo but its not
change the cap and rotor, while your at it change the plugs and wires.
the cap could be carbon cracked from hell, or the pin inside the cap could be broken off like mine was
