help on a 88 hf
put a new wire harness on and went to start the car. it did nothing. the only thing that will come on is the hazards. headlights, brake lights, dash lights, etc. nothing works. i checked all the fuses and they are ok. any help is greatly appreciated.
did you check all the onnectors to your starter motor.also try and see if you can hear the fuel pump when you hit your key all the way.also ee if its your main relay.if it doasent clik then its either that or the wires to your starter motor.the litle wire that connects to it(not the fat one witch is the one that comes from your batery)i hope this helps
ya.the hazards are always to work because there an independant circuit.but did you check the wires to the starter.and can you hear the main relay click.because the wire i was tellin you about.. the litle one that goes to your starter comes from your harness.
did you check all your main fuses..they look like litle black boxes but they got like a litle window so you can see whats goin on.chack all your harness strut plugs..dammm. you really got me thinking
Chr1spy
Mar 28, 2013 11:53 AM
