b16 with gsr head??? what happens???
Old Apr 15, 2006 | 02:52 PM
Kevinarich's Avatar
Default b16 with gsr head??? what happens???
I ran across this b16 that has a gsr head. is a bad thing, or is this a good thing. what does this do to my compression and what does this do the rest of the motor. can i use a b16 distributor on a gsr head? help me?
Old Apr 15, 2006 | 02:54 PM
Slopoke's Avatar
It lowers your compression slightly.
Yes you can use a b16 dist.
Old Apr 15, 2006 | 02:55 PM
ev13lf's Avatar
Default Re: b16 with gsr head??? what happens??? (Kevinarich)
i dont know the specifics, but to the best of my knowledge having a gsr head on a b16 bottom end isn't necessarily bad for the engine at all. it should work no problem, you'll just have a slightly lower compression ratio i think. what happens is the motor runs fine if the head was put on correctly.
Old Apr 15, 2006 | 03:31 PM
Kevinarich's Avatar
so i could run a 2 ply head gasket to make the ratio higher. i get this and i get an ls tranny for 650 so im not comlaining. the rest of the money will go to rebuilding it, i really want the individual throttle bodies, and some high comp pistons. any one know where i can score a ctr tranny for not so much? or better yet maybe i could spend some money on the tranny and get it rebuilt with those fangled spoon gears and that there lsd. it would work right?
88 EF Hatch
Nov 27, 2008 06:45 PM
90B16aCRXsi
43
Jul 30, 2008 08:50 PM
my4drGSR909
Jan 15, 2007 11:54 PM
maziospzza
Dec 2, 2004 12:33 AM
lastpunkinline
Apr 16, 2004 11:09 PM
