93 civic hatch (cx) for sale plus sohc parts
I ahve a 93 civic hatch (cx) kinda gutted for drag racing. still has door panels and dash, carpet but fuel tank was taken out for a fuel cell, still have tank w/walbro 255 intanke fuel pump but needs new fuel line. Eibach 1050# rear drag springs, cheap brand coil overs all the way around. Engalls adjustable camber kit all the way around. the car is in black primer. Has a hand made fiberglass hood, have stock one also. $500
Have fully build 79 mm D16Z6 for sale will piece out if needed.
motor has sheet metal intake w/camp 440cc inj, w/65mm tbi will seperrate from motor make offer.
MSD 6AL box with SS coil, Cap and plug wires all MSD
D16Z6 short block with Aries 11:1 CR with LS rods new water pump,new time belt, new oil pump, needs head. has the oil pan on it also.
make offer on parts.
$500 for the body which includes 1050lbs Ebiach rear drag springs, Engles camber kit front/rear. cheap adj coil overs. 93 hatch cx body with homemade fiberglass hood plus factory hood, i pulled the factory tank out and i had a 1gal fuel cell in it but i have the tank with awalbro 255 fuel pump also. You will need to get factory fuel lines if you run the factory tank since i took them out.
you still happen to have the back seat from the car by any chance?? if so and it's black vinyl I'd be interested
bump for you
bump for you
ALLMOTORD16Z6
Jun 5, 2006 02:57 AM
