Dualpoint Wiring Diagram..?
Hi guys, I've tried searching but the search engine is down...
I'm looking for the engine wiring diagram for a 89 Honda Civic Hatchback DX (I've found the diagram for FuelInjected Systems, SI & HF, but can't seem to find the DX one!).
Thank you!
Thank you!
I'm droppin in a JDM first gen B16. I know wut all the wires coming the b16 harness is, but I have no diagram of the DX harness that includes the wires and their plugs (you know the plug with 11 wires on the driver side, the L-shaped plug and the "big" pug on the passenger). If I knew wut those plugs and wires were then I could get my car running (the motor, axles mounts - thanks to hasport - and all necessary hoes are all in), I just need the wire diagram so I could plug the correct wires into the correct plugs of the DX harness - and of course, adding the necessary wires for the additional 02 sensor, knock and VTEC wires.
If not, thanks anyway, I might just have to take out the whole harness from the car and firewall and separate them until I know which is which. In that case, I'm not too exciting to do.
thanks, but I found that after the fact my brother shredded the stock harness into 9 pieces. I don't know wut he was thinking, so now I have to use other means, that's why I need the dx wire diagram.
Again, thanks for the info
damn , sorry to hear that man .. you should be able to buy another harness pretty cheap if you wanted .. but either way , i hope you get it runnin soon man . i bet thats a bitch looking at it there in the bay and cant drive it .
h224thgensedan
Jan 23, 2007 05:28 AM
importboi22
May 31, 2004 02:31 PM
infamousALLMTR
Sep 13, 2003 09:15 PM
FourthGenHatch
Sep 2, 2003 04:20 AM
