Turbo Exhaust piping route, factory or different piping route
Old Apr 15, 2006 | 10:50 AM
b18sihatch's Avatar
Default Turbo Exhaust piping route, factory or different piping route
ok so i have a apexi n1 3'' catback exhaust that retains stock piping route, and i also have a 2.36 rsr gt2 catback exhaust that doesnt retain the piping route it is a straight threw design totally straight as most of you prolly know rsr... my question is what would be better for turbo? i know the 3'' will give more flow, but the rsr has a straight threw design, would you say givin one is 3'' and one is straight threw, that would make them pretty equal on flow? any opinions
Old Apr 15, 2006 | 10:53 AM
itsJDMyo's Avatar
Default Re: Turbo Exhaust piping route, factory or different piping route (b18sihatch)
i'd like to know also
Old Apr 15, 2006 | 01:44 PM
b18sihatch's Avatar
Default Re: Turbo Exhaust piping route, factory or different piping route (itsJDMyo)
i know the larger piping diameter will give better flo, but the straighter smaller exhaust should give better velocity flow giving the exhaust shoots straight out... anyone with me?
Old Apr 15, 2006 | 04:50 PM
92gsrteg's Avatar
I'd say go with the 3" because its gonna allow more volume of air to escape and the velocity wont have to be as fast as the smaller exhaust cause its still gonna allow more air to flow, for example, blow into a 5 foot long piece of hose with a small inner diameter and blow into a slighty larger in diameter 10ft. long piece of hose, ur gonna be able to blow more air out of the larger diameter hose even though its longer, the air coming out wont have as much velocity to it but ur still moving a larger volume of air, its all about volume and speed really doesnt matter here.
3" all the way even if its longer and bends more, i take it that its mendral bent so it doesnt matter anyways. having a smaller and bending exhaust would be a problem though. seeya
Old Apr 15, 2006 | 05:02 PM
b18sihatch's Avatar
Default Re: Turbo Exhaust piping route, factory or different piping route (92gsrteg)
thing is my car is a ef and the only biggest piping i can use is going to be 2.5 downpipe for clearence issues, so my question is i see people who use a 2.5dp and 3'' catback, but if you think about it, the downpipe is the part of the exhaust that is going to be flowing the larger volume of air, so if you have a 2.5dp and 3'' catback, the 3'' diameter piping isnt going to bwe flowing more volume of air, the most air you are going to be moving is threw the 2.5''dp
kinda like this, if the downpipe flows 1000 litres of air a minute, adding a 3'' catback wont make the downpipes air flow anymore. not like if you have a 3'' turback... does that seem pretty straight
Old Apr 15, 2006 | 06:05 PM
SlwGsr's Avatar
people like to see 3'' after the dp bc it flows better then if you keep 2.5 all the way through. either way. the quickest you can get to bigger piping the better. even if its right after the dp.
Old Apr 15, 2006 | 06:59 PM
b18sihatch's Avatar
ok let meask you this tho, i am trying to get a wide range of view on this exhaust/velocity/flow ****..... say you are running a maximum of 8-10psi do you think 2.5in turboback would be efficent?
Old Apr 15, 2006 | 07:23 PM
Soccerking3000's Avatar
yea that would be fine you might sacrifice some spool but thats it
Old Apr 15, 2006 | 07:42 PM
ccivic's Avatar
Default Re: Turbo Exhaust piping route, factory or different piping route (Soccerking3000)
You should be able to flare the downpipe to 3" no matter what chassis it's in. 3" all the way.. no reason to go smaller. You will see decreases in spool time even with a 2.5" downpipe compared to a smaller exhaust.
Old Apr 15, 2006 | 08:22 PM
Default Re: Turbo Exhaust piping route, factory or different piping route (ccivic)
hears a question for you then would there be any benefit of running a 3 inch downpipe with a 2.5inch exhaust? AS opposed to 2.5 all the way back would there be any gains?
Old Apr 16, 2006 | 08:05 AM
b18sihatch's Avatar
i would say you would have serious backflow with a 3'' dp and a 2.5in dp back
Old Apr 16, 2006 | 09:33 AM
b18sihatch's Avatar
i just dont see it tho, i mean without better explain why a 2.5in turboback would be less efficent that a 2.5-3.0'' exhaust, you WOULD think that a 2.5 turboback would have better spool times bc it would carry a velocity flow of 2.5'' from the downpipe back, unlike the 2.5in dp and then 3'' catback, you would think it would have high velocity flow when the air comes down and out the 2.5in downpipe, then the velocity would slow down bc it reaches a larger diameter piping, would think it wouldnt be as direct of a velocity flow does that make any sense?
Old Apr 16, 2006 | 05:47 PM
b18sihatch's Avatar
anymore opinions
Old Apr 16, 2006 | 07:35 PM
sauceja's Avatar
side exit exhaust with 3" piping.
Old Apr 17, 2006 | 08:29 AM
b18sihatch's Avatar
Default Re: Turbo Exhaust piping route, factory or different piping route (sauceja)
anyone else?
Old Apr 17, 2006 | 10:44 AM
stewie8apie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">side exit exhaust with 3" piping.</TD></TR></TABLE>
i second that
general rule of thumb w/turbo setups and exhaust..."Bigger is Better"
i'd say go with either the 3" n1 or custom side exit. plus the side exit just looks cool IMO.
Old Apr 21, 2006 | 09:36 AM
b18sihatch's Avatar
Default Re: Turbo Exhaust piping route, factory or different piping route (stewie8apie)
how would side exit with 3'' piping sound tho? any tone or just completely loud?
Old Apr 21, 2006 | 10:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">how would side exit with 3'' piping sound tho? any tone or just completely loud? </TD></TR></TABLE>
lol it would sound fine as long as you put the necessary resonators and such on it
Old Apr 21, 2006 | 10:43 AM
b18sihatch's Avatar
uggghh i really love the sound and performance of my rsr gt2 catback ehaust, i would hate to sacrafice performance for sound, but i wont want sumthing just completely loud sometimes the apexi n1 can get loud like that, and the apexi n1 alot of ppl have, not alot of ppl have the rsr gt2 grr choices choices
Old Apr 21, 2006 | 02:10 PM
sauceja's Avatar
Loud is a byproduct of performance. Not much I can do to help you there.
Old Apr 21, 2006 | 03:21 PM
b18sihatch's Avatar
does anyone happen to havea sound clip of a side exit exhaust?
Old Apr 26, 2006 | 09:16 PM
b18sihatch's Avatar
how do you guys think a gt2 rsr with 3'' piping would sound? ive heard them with NA but never with turbo ? ?
prime-R
11
May 9, 2009 01:44 AM
JesseBizz
Jun 29, 2008 05:23 PM
javon972
Jun 25, 2008 03:21 PM
Nothing.Special
Mar 8, 2003 09:46 PM
TJP_AccordV6
Oct 10, 2002 11:58 AM
