Primer Help
Old Apr 6, 2002 | 05:43 PM
MisterB's Avatar
Default Primer Help
ok i just primered my 91 hatch a light grey and it is all blochy, I took a buffer to it and that aint help, and 220 grit sand paper leaves scratches... i never primered anytbing before but what can i do to smooth out the paint and make it blend together better
Old Apr 8, 2002 | 09:07 AM
Cryptopsy's Avatar
Default Re: Primer Help (cl4show)
Ok, use THIN layers of primer in long sweeping patterns. Use 600 grit WET sandpaper to smooth it out. yes...200 will scratch. IM me if you need more help.
Old Apr 8, 2002 | 09:28 AM
slickboy's Avatar
New User
Default Re: Primer Help (SoulflyCRXsi)
600 grit is better...anything under 400 will scratch badly. I would even suggest using a 1000-1500 grit wet sandpaper after a 600-800.
Old Apr 8, 2002 | 01:45 PM
MisterB's Avatar
Default Re: Primer Help (slickboy)
ok thanks guys ill try to wet sand it with 600 or more grit and see how it comes out
mistik_DC4
Oct 27, 2008 02:37 PM
PHILEE
Paint and Body
14
Apr 26, 2008 05:16 PM
spool310
Paint and Body
52
Mar 3, 2008 12:33 PM
Shingo
Aug 6, 2005 10:43 PM
CRXSolid
May 3, 2004 08:51 AM
