need help putting my fuel lines together
Old Apr 14, 2006 | 09:03 PM
bracket 4 life's Avatar
Default need help putting my fuel lines together
I just got some -6an braided fuel lines and I am having problems putting the ends on the lines, the middle slides all the way in, but the outside pops out and it looks like $hit
any help will be greatly appreciated, also how do you cut the lines?
Old Apr 14, 2006 | 09:06 PM
.dave's Avatar
i HAS questions ?
Default Re: need help putting my fuel lines together (infamousCW-hatch)
I wrap masking tape tightly around the area I want to cut, then use a dremel with a cut-off wheel to cut through it. Then put a little oil on the tape and slide it into the fitting.
Old Apr 14, 2006 | 09:08 PM
Default Re: need help putting my fuel lines together (daveG)
that is the way I was trying but the outside of the line keeps slididng up and bunching right infront of the fitting and just letting the middle slde in
Old Apr 14, 2006 | 09:16 PM
weiRtech's Avatar
OG Fabricator
wrap it with electrical tape, it works better and you can wrap it tighter. i hold it in a vise and cut it with a hack saw, but with almost no pressure so it doesn't fray the braiding. once i get half way though i hold the other side of the hose with some pliers to prevent it from moving. it seem to make a pretty clean cut.
you don't slide the hose into the aluminum coupling. you should twist it COUNTERCLOCKWISE. there is an internal thread in the coupling that helps hold the hose together when you thread in the other part of the hose end.
you should also use assembly lube meant for these hose ends. i don't know the name of it because i don't have any. i just usually spray a bit of silicone lubricant on the fitting and inside the rubber part of the hose when i thread the second part on, that is all.
Old Apr 14, 2006 | 09:18 PM
Default Re: (weiRtech)
ok I will have to try that way, it sounds pretty good, i ordered enough to be able to mess up a couple of times
Old Apr 15, 2006 | 08:13 AM
vaporboy12's Avatar
Default Re: (infamousCW-hatch)
putting hose ends together is a royal pain in the *** till you get a hang of it... use earl's oil and twist them in dont not push them in. once you do a few your get a hang of it. also as they say wrap the tape as tight as possiable
Old Apr 15, 2006 | 10:19 AM
Default Re: (vaporboy12)
cool thanks alot guys
Sorcerer
Jan 21, 2017 11:13 AM
95accordian
Jul 19, 2016 08:35 AM
Marcg611
Aug 10, 2010 05:24 PM
blackeg
Mar 18, 2007 05:32 AM
bracket 4 life
Apr 21, 2006 04:37 AM
