integra front suspension
Old Apr 14, 2006 | 01:52 PM
dc5mikeydc5's Avatar
Default integra front suspension
ive been searching and cant find a strait answer. im puting my old 90 integra rear suspension brakes and sway bar on my 90 std. heres my ? can i use my front sway bay on my car with out changing the suspension or will I have to change the front suspension 2.
Old Apr 14, 2006 | 01:56 PM
Tyson's Avatar
Default Re: integra front suspension (mikeymixta)
youll need the brackets for the bushing. #2. theyre different than the integra ones.
btw, how are you planning on bolting the rear swaybar to your STD? the threaded holes are not there on your car. in other words, it wont bolt up like normal.
Old Apr 14, 2006 | 02:00 PM
Default Re: integra front suspension (Tyson)
what if i just use my lower control arm of the front and keep the rest stock will that work. for the rear sway bar im gonna im swapping the whole suspension. as for the mounts mounted on the bottom of the car my friends a certafied welder. so im gonna drill and tap the holes then also weld them.
btw were did u get those pictures like that with the part break down
Old Apr 14, 2006 | 02:09 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeymixta &raquo;</TD></TR><TR><TD CLASS="quote">what if i just use my lower control arm of the front and keep the rest stock will that work. </TD></TR></TABLE>
its not about the LCA. that brackets bolts onto the subframe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">for the rear sway bar im gonna im swapping the whole suspension.</TD></TR></TABLE>
you should be using ONLY your old civic control arms, front and back. swap only the knuckles and trailing arms. dont use ANY integra control arms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">as for the mounts mounted on the bottom of the car my friends a certafied welder. so im gonna drill and tap the holes then also weld them.</TD></TR></TABLE>
sounds fine. as long as you know youre going to need some kind of custom fabrication to make these work. heres a link on a good way of making them fit.
https://honda-tech.com/zerothread?id=1146145
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">btw were did u get those pictures like that with the part break down</TD></TR></TABLE>
http://www.slhondaparts.com/br...5MTKA
Old Apr 14, 2006 | 10:28 PM
bump thanx for the good info
Old Apr 14, 2006 | 11:03 PM
JapJunkie's Avatar
Tysons such a nice guy
JAYBOOGIEZZ
Suspension & Brakes
16
May 9, 2007 05:02 PM
thehatchninja
10
Dec 23, 2002 12:08 AM
yoshio006
Sep 14, 2002 11:22 AM
96 SOHC VTEC
Jun 17, 2002 07:39 PM
