My Lsvtec runs @ 210oF to 220oF water temp. Is that normal???
Old Apr 14, 2006 | 12:12 PM
deepbluepentium's Avatar
Default My Lsvtec runs @ 210oF to 220oF water temp. Is that normal???
I have a Ls vtec in my eg hatch. I have a fully built head and redlines at 9k. I have the stock radiator and fan. Since im on a budjet now, I was wondering if replacing the radiator with one from an integra would help. If not, and i have to buy an aftermaket radiator would i have to get a fan as well? Or do i just replace the fan with one that produces more cfm? if so wich one?
Old Apr 14, 2006 | 03:09 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: My Lsvtec runs @ 210oF to 220oF water temp. Is that normal??? (deepbluepentium)
Replace your thermostat with one from the honda/acura dealer.
Old Apr 14, 2006 | 03:32 PM
Default Re: My Lsvtec runs @ 210oF to 220oF water temp. Is that normal??? (PURPLETERROR aka BIGMATT)
I just had a water temp gauge installed. Would the thermst cool my engine?
Old Apr 14, 2006 | 06:35 PM
djtony5's Avatar
that temp is normal. my gauge read 200-220.
Old Apr 14, 2006 | 07:25 PM
Blackack26's Avatar
Default Re: (djtony5)
T-stat should fully open at 194 deg F
This is for a b18.
Old Apr 14, 2006 | 08:33 PM
92bluepreludeSi's Avatar
Default Re: (Blackack26)
attention all ricers! stop building engines if you dont know what your doing.
Old Apr 15, 2006 | 05:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtony5 &raquo;</TD></TR><TR><TD CLASS="quote">that temp is normal. my gauge read 200-220.</TD></TR></TABLE>
Sorry, that temp is not normal, find out what an oem honda thermostat is rated at and get back to me. My car runs at 180 on a cold day and 190 at the most on a very warm day.
Old Apr 15, 2006 | 08:59 AM
Blackack26's Avatar
Default Re: (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry, that temp is not normal, find out what an oem honda thermostat is rated at and get back to me. My car runs at 180 on a cold day and 190 at the most on a very warm day.</TD></TR></TABLE>
I posted the oem b-series t-stat rating above, 194 def F.
But yeah 200-220 isn't normal, i'm at 185-190 on warmer days, this is with the full sized integra radiator.
Old Apr 15, 2006 | 03:21 PM
So what should i do? Should i buy an aftermarket radiator for a civic (Half size looking one) or for an Integra. Can i get away with the stock fan as well and still get a cooler engine?
Old Apr 15, 2006 | 04:31 PM
djtony5's Avatar
Anything between 185-215 is normal as stated in the helm manual. The reason why I stated mine run 200-220 is 200 for daily driving and max 220 when I push the car down the track or something and that is around when the fan kick in.
Old Apr 17, 2006 | 05:31 PM
ok so i just talked to my mechanic and he said that an integra radiator won't fit in my eg hatch?! Then other people say it does. Does anybody know if and aftermarket integra radiato fits in a hatch??
Old Apr 17, 2006 | 11:04 PM
Blackack26's Avatar
Default Re: (deepbluepentium)
Wont be a direct bolt in, probably have to modify the mounts.
acc0rdf22
Apr 11, 2010 03:05 PM
brandond
Nov 6, 2005 02:59 PM
budget
Jun 5, 2005 11:03 PM
