Ignore, if you're sick of tire threads...
Old Apr 14, 2006 | 11:18 AM
That'll Leave A Mark's Avatar
Default Ignore, if you're sick of tire threads...
I'm due for new street tires. I'm running stock springs w/Bilsteins on the lower perch and camber as close to 0 as alignment adjustments will allow (my last alignment specs are at home, or I'd look up the numbers). Haven't measured it recently, but the drop in ride height is roughly a centimeter, IRCC. Stock rims and tires have no clearance issues. Haven't tried stock rims and 205-50/15's with this setup. I'm also considering switching back to 15x7 +38 Kosei K1's, but they rubbed occasionally with the stock dampers/ride height, and if they're going to rub any more with the current setup, I'd rather stick with the stock rims. Suggestions?
Anyone have experiece with stock springs + Bilsteins/lower perch + stock rims + 205-50/15's? How about the same setup, but 15x7 +38's instead of the stock rims? How about 205-55/15's?
Old Apr 15, 2006 | 01:26 AM
SoCal ITR's Avatar
Default Re: Ignore, if you're sick of tire threads... (That'll Leave A Mark)
two cents..
no problems lowered with 205/50's on stock rims
205/55's are too tall and will throw off the speedo
Might want to try a higher offset if you want to run 15x7's and a 205/50
Also, for tire sugestions, try searching. There have been a thousand threads on it.
xander1100
Aug 11, 2009 08:54 PM
JDM 101
Nov 16, 2007 08:18 PM
ZakkWylde
Honda Civic (2001 - 2005)
12
Jun 9, 2007 01:59 PM
itrdave
Jan 30, 2007 12:05 PM
paulyman
Feb 26, 2002 02:50 PM
