88 CRX door panels and dash fit into 91 EF?
Old Apr 14, 2006 | 11:14 AM
DETurbine's Avatar
Default 88 CRX door panels and dash fit into 91 EF?
I just wanted to check and make sure that the dash and interior door panels will work from a 88 CRX into a 91 EF?
I was told that I might need to pull the CRX vent piping from behind the dash.
Old Apr 14, 2006 | 11:18 AM
CRX Toad's Avatar
Default Re: 88 CRX door panels and dash fit into 91 EF? (DETurbine)
91 EF? Are you saying a Civic?
Everything should swap across
Old Apr 14, 2006 | 12:01 PM
PrestonCRX's Avatar
i swapped a 88 crx dash into my 89std hb civic bolts right up
Old Apr 14, 2006 | 12:41 PM
DETurbine's Avatar
yes sorry....meant civic. So the door panels and all should swap right over without any troubles?
Old Apr 14, 2006 | 01:12 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (DETurbine)
I doubt the door panels will work as the '88 model
did not have the door mounted seat belts..
Old Apr 14, 2006 | 01:19 PM
PrestonCRX's Avatar
you'll need 90-91 crx door panels with the seatbelts in the door
Old Apr 14, 2006 | 01:20 PM
SuperHonDad's Avatar
Default Re: (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">I doubt the door panels will work as the '88 model
did not have the door mounted seat belts..</TD></TR></TABLE>
Thats right!
The 90-91 have the seat belts in the door and the 88-89 have the seat belt on the body. But the dash will bolt in dont forget the center console out of the CRx. the one inthe Civic faces straight back and the CRx one faces the driver.
Old Apr 14, 2006 | 05:44 PM
civhatch90's Avatar
89 crx si also has door mounted seat belts
Old Apr 14, 2006 | 06:40 PM
1989CivicSi's Avatar
Default Re: (civhatch90)
Well, unless you've got a Canadian car, you're stuck with the door mounted versus pillar mounted belts.
Dash should work fine though.
Old Apr 14, 2006 | 08:39 PM
DaNnYsEvEn's Avatar
actually it does work but you have to do a small cut and eliminate the door seat belts and mount them on the pillar. i already swapped over one door panel and it fit pretty good. some holes didnt line up but its snug and doesnt move... i bought the door panels not even knowing they were different..i actually bought the whole interior. but so far so good...il take some pics tomorro after work.
Old Apr 15, 2006 | 07:48 AM
DETurbine's Avatar
thanks to all for the help.
Let me know about those pictures if you could...
Old Apr 15, 2006 | 04:54 PM
DaNnYsEvEn's Avatar
okay here are some pics i took.
in the yellow circle thats what you have to cut out, because the panels are a bit longer.
old
new
heres the door fitted. solid as a rock
you have to remove this piece. its on the rocker panel.
also dont forget to remove this piece as well. the top part where the seat belt hangs.
now when you connect the door panels,i suggest reusing the old white door clips. the small compartment your going to have to use a bit longer screw and screw it in at an angle. other than that its pretty easy...bare with me on the pics...my camera sucks but atleast you get an idea of what im talken about.
Old Apr 15, 2006 | 05:28 PM
408wdy's Avatar
Default Re: (DaNnYsEvEn)
damn your pictures are dark cant see shyt
Old Apr 15, 2006 | 05:34 PM
DETurbine's Avatar
thanks for those pictures.....they are a little dark, but I get the idea of where it should be cut at. Good enough for me.
Thanks for the pictures and help on that.
quirarte626
Apr 27, 2009 07:04 AM
jdmb20boi
Jul 10, 2008 06:27 PM
DaX
Feb 23, 2006 06:51 PM
joeyblow
Oct 2, 2005 02:41 PM
Hayasa15
Feb 9, 2002 07:20 PM
