need explanation of #34 in parts diagram, goes between outer and inner tierods ???
Old Apr 14, 2006 | 09:01 AM
crxaddikt's Avatar
Default need explanation of #34 in parts diagram, goes between outer and inner tierods ???
i do not see this nut on my old steering rack i took out or on the new one, and i am told it is important and that if i don't have this that everything will fall apart while driving, so i just need an explanation of this please?
on my new outer tie-rods the ends are hex shaped and they screw right onto the ends of the rack, but between the boot ends and the end of the rack there is no nut like the one shown as #34 in that diagram??? i must be missing something but its not on my old rack or the new rack ???
http://www.hondaautomotivepart...E+ROD
the ends of the rack are threaded but have one section that is hex-shaped and does fit a 14mm wrench but it is'nt a nut of any sort its just the end of the rack, so i don't know, i just need an answer, thanks for any info
Old Apr 14, 2006 | 11:25 AM
lightcrx's Avatar
thats a lock nut, id just find out what thread it is and go to our local hardware store and get one
you need it you dont wat your alignment changing all by it self
-joseph
Old Apr 14, 2006 | 11:42 AM
crxaddikt's Avatar
Default Re: (lightcrx)
ok thanks, i am going to delete this post cause i understand it now
Stea
20
Jul 10, 2021 07:14 PM
V_Xero
Jan 21, 2014 06:47 AM
Vagitarian
17
Jun 4, 2012 04:20 PM
blasterman87
Jan 17, 2010 06:13 AM
looxs
Jun 27, 2006 01:49 PM
