rear sway bar: ctr vs itr
im not referring to the diameter of the bar... cant find the actual answer to this anywhere: i have a 94 eg ex sedan w/a stock rear sway bar. do i have to buy the itr bar? or can i use a ctr bar? the endlinks are different i can see that but can i use a ctr bar with the endlinks off my stock sway to mount it? i already have the beaks kit... just wondering about fittment and endlinks. thanks all
The CTR bar will require the CTR or 99-00 end-links (ball-joint style). For your car, you can re-use your stock end-links if you get the ITR bar.
