HOW DO YOU KNOW IT'S A GSR TRANNY
Old Apr 13, 2006 | 10:33 PM
oldskoolracer's Avatar
Default HOW DO YOU KNOW IT'S A GSR TRANNY
ok i went out and got a tranny that i thought was a GSR now i don't know
it's tagged y80 if i remember correctly but my other GSR is a s80
i tried to look and everywhere it says that they both could be a GSR OR an LS tranny how do you know does anyone know how to read into the other #'s on that sticker i need one of these to put in my QUAIFE and i don't want to try and fit it into an ls tranny then start over with the right one or atleast know they are the same
Old Apr 14, 2006 | 12:21 AM
Zubaltec's Avatar
Default Re: HOW DO YOU KNOW IT'S A GSR TRANNY (oldskoolracer)
You'll know as soon as you crack it open. If the ring gear fits on your "known to be GSR Quaife" then thats what you got- a GSR trans. If not it a B16 or LS trans.
Also the middle shift fork is different on a LS then a B16 or GSR.
Old Apr 14, 2006 | 12:37 AM
smokey2.0's Avatar
Default Re: HOW DO YOU KNOW IT'S A GSR TRANNY (Zubaltec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zubaltec &raquo;</TD></TR><TR><TD CLASS="quote">You'll know as soon as you crack it open. If the ring gear fits on your "known to be GSR Quaife" then thats what you got- a GSR trans. If not it a B16 or LS trans.
Also the middle shift fork is different on a LS then a B16 or GSR.</TD></TR></TABLE>when you open it, just look at the diff. it should say S80 if it's a gsr, and S1 if a b16/ls
Old Apr 14, 2006 | 05:46 AM
i've been trying to figure out a way to know with out pulling it apart
Old Apr 14, 2006 | 11:44 AM
Mr.E.G.'s Avatar
Default Re: (oldskoolracer)
well if you want to get creative you could install axles and rig up a crue measuring device so you can calculate how far each axle rotates per turning the shaft. reverse mathify it using known gear ratio and final drive ratio and you can determine which tranny you have. you could probably do all of that with some creativity and a tripto home depot.
Old Apr 14, 2006 | 12:12 PM
tony1's Avatar
Default Re: (Mr.E.G.)
lol, i think it would be easier to open the trans and count some teeth!
Old Apr 14, 2006 | 12:41 PM
RaceSleeves's Avatar
Default Re: (tony1)
Asking it what it came out of would be easier then putting in the axles and counting the revs! lol
Seriously I would take it apart...
Howard
Old Apr 14, 2006 | 12:42 PM
tony1's Avatar
Default Re: (RaceSleeves)
lol
Old Apr 14, 2006 | 01:04 PM
YEAH ALL OF A SUDDEN TAKING IT APART SOUNDS EASIER,LOL
Old Apr 14, 2006 | 01:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldskoolracer &raquo;</TD></TR><TR><TD CLASS="quote">YEAH ALL OF A SUDDEN TAKING IT APART SOUNDS EASIER,LOL
Good call...
Old Apr 14, 2006 | 04:03 PM
SiKnezzALLmotor's Avatar
its a gsr trannyy80 came off the 95 gsr
Old Apr 14, 2006 | 10:35 PM
JohnnieChimpo's Avatar
Default Re: (SiKnezzALLmotor)
Take it appart are you people idiots?!?!
Put a used clutch disc on it (or not disc just makes it easier) make a mark on the clutch (or shaft) and the bellhousing.
On the axle side make a mark on the housing and the diff or slide an old CV joint in there.
Put the shift linkage into 5th.
Turn the clutch until the diff makes one full turn.
3.05 (just past 3 turns) is an LS. 4.266 x 0.714
3.46 (almost 3 and a half) is a GSR. 4.4 x 0.787
It'll take you 5 minutes vs. OPENING your transmission.
Opening your trans if for people who still do math on their fingers.
Old Apr 15, 2006 | 06:26 AM
Zubaltec's Avatar
Default Re: (JohnnieChimpo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">Take it appart are you people idiots?!?!
Opening your trans if for people who still do math on their fingers. </TD></TR></TABLE>
Idiots are people like you who buy a used trans and just put it in your car without going through it. To make sure everything else is good.
Old Apr 15, 2006 | 07:38 AM
AR Fab's Avatar
Default Re: (Zubaltec)
John john john john........its HT they know how to do it better then all of us...
Old Apr 15, 2006 | 10:08 AM
tony1's Avatar
So how do you tell if it's a GSR or B16 tranny?
Old Apr 15, 2006 | 10:15 AM
D@nnY's Avatar
Default Re: (tony1)
pull off the axle seal and look in there....youll be able to tell by what kind of bearing it has...gsrs have tapered roller bearings Ls and b16 have sealed ball bearings...
except for the 2000-2001 gsr that will have the same sealed ball bearing as a Type R ...whgci is bigger then the b16 Ls bearings.... unless you have a newer gsr transmission you should not see a sealed ball bearing on the diff...
or you could be like the idiot that just called everyone idiots and do it the ******** way
also if you open it you can just look at the 3rd gear sleeve set .....theres a U on the middle hub...on gsrs it will be upside down like this" n " and LS b16 " u"
Old Apr 15, 2006 | 11:56 AM
Mr.E.G.'s Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">lol, i think it would be easier to open the trans and count some teeth! </TD></TR></TABLE>
hey hey hey, i was just trying to help him come up with a way to not have to take it apart. i can only with with what you guys give me
Old Apr 15, 2006 | 11:57 AM
Mr.E.G.'s Avatar
yeah goddammit, thats what im talking about
Old Apr 15, 2006 | 05:53 PM
reaction360's Avatar
umm...drive it? haha das how i always tell if its a gsr, ls or b16. cruising speed on the freeway at 60mph in 5th gear should usually tell u what tranny it is. i know thats a primitive way of doing it but its always worked for me haha.
Old Apr 15, 2006 | 08:20 PM
Default Re: (reaction360)
The guy who started this thread said,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldskoolracer &raquo;</TD></TR><TR><TD CLASS="quote">i've been trying to figure out a way to know with out pulling it apart</TD></TR></TABLE>
I answered him. Then the peanut gallery has to try to twist the question to meet their poor answers and make me out to be a dick.
Idiots are people like you who buy a used trans and just put it in your car without going through it. To make sure everything else is good. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AR Fab &raquo;</TD></TR><TR><TD CLASS="quote">John john john john........its HT they know how to do it better then all of us... </TD></TR></TABLE>
Is you read what he wrote you would see that he is going to open a known GSR trans to put his Quaife in. I stick by my original assessment of you guys.
Old Apr 15, 2006 | 08:35 PM
Mr.E.G.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">The guy who started this thread said,
Is you read what he wrote you would see that he is going to open a known GSR trans to put his Quaife in. I stick by my original assessment of you guys.</TD></TR></TABLE>
your answer sounded like the easiest route to me.
Old Jun 5, 2006 | 08:42 AM
TrackSpeedRacing's Avatar
has anyone else tried this method for finding out if they have an LS or GSR tranny?
Old Jun 5, 2006 | 05:20 PM
JV's Avatar
JV
Who?
https://honda-tech.com/zerothread?id=850751
Old Jun 5, 2006 | 05:43 PM
CroteTurbo's Avatar
Default Re: (TrackSpeedRacing)
I did but not with the same test but the same math.
For someone who don't know alot, 5th gear is easy to find because of the reverse.
Old Jun 5, 2006 | 08:36 PM
bigTom's Avatar
this is your problem, who the hell are you to be calling people idiots? especially with people on this board who know what they are talking about?!
without this line your post would have been fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">It'll take you 5 minutes vs. OPENING your transmission.
i open tranny's in less than a minute (yes iv timed myself)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">Opening your trans if for people who still do math on their fingers. </TD></TR></TABLE>
r u an idiot? who wouldnt open a tranny to check it out in the first place!
