Re-did brake lines....fluid only goes to 1 wheel??????
Old Apr 13, 2006 | 10:22 PM
b.d.racing's Avatar
Default Re-did brake lines....fluid only goes to 1 wheel??????
I re-did all my brake lines since the car is stripped down now and I only seem to get brake fluid going to the rear drivers side wheel. I've got all the lines going to the proportioning valve just like they're supposed to, no leaks at any of the fittings, and no crazy bends that would block flow. When I press the brake in I get flow going through the lines going to the proportioning valve which I know because of having to redo the fittings. Can a proportioning valve block fluid flow? Somebody hook me up with some knowledge because this whole thing was a nightmare to begin with.
Old Apr 14, 2006 | 07:02 AM
b.d.racing's Avatar
Default Re: Re-did brake lines....fluid only goes to 1 wheel?????? (b.d.racing)
need answers
Old Apr 14, 2006 | 07:06 AM
wacrxguy's Avatar
How do you know that you are only getting fluid to the Drivers right?
Have you bled the whole system really well. If the whole system was drained it could take quite a bit of fluid to get all of the air out.
Old Apr 14, 2006 | 07:17 AM
aka's Avatar
aka
Im not sure about this but I think you need to get the fuild past the check valve.
You may need to press the brake and hold it...loosen the bleeder to let the air out and re tighten it...take your foot off the brake, wait a couple seconds...repeat the process
He is right... it will take a long time. My four wheeler took about 15-20 to prime.
Old Apr 14, 2006 | 08:53 AM
b.d.racing's Avatar
Default Re: (aka)
OK cool I'll try
prodjay10
May 2, 2016 07:25 AM
Olivier Maltby
Suspension & Brakes
Dec 13, 2012 08:26 PM
Jaydeep
Jun 25, 2012 09:25 PM
b.d.racing
Apr 14, 2006 04:48 PM
wessieball
Jul 30, 2002 08:32 PM
