Removing rear main seal from housing?
I have the rear main seal housing off my block and im trying to replace the seal with a new one but i cant get the damn thing out of the housing... does it need to be pressed out?
You can press it out or tap it out. If it doesn't come loose try poking an aww or small screw driver into it to help pry it out.
To put the new one in go easy on it. Press it or tap it in evenly with something that will give a little, like plastic, rubber or wood.
djfob
Dec 2, 2011 11:05 AM
EF9_TryMe
Apr 20, 2010 01:57 PM
