crx dx and a d16z6
well i may be purchasing an 88 dx soon and already have a z6 to grab. the thing i si dont know what ill be needing for the swap since im learning through all this. if swap the engine over with everything such as the distributor, throttle body, injectors, and manifold would that be everything i need or would i need to go obd1 on top of that? i tried searching and didnt find much help and sorry if i just sound dumb with everything i said.
http://rywire.com/store/produc...id=66
here this is where you can get the wiring.
but i say go dohc vtec those are just to little..
but hey do want you want
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX DX 2 LS BobbyG »</TD></TR><TR><TD CLASS="quote">serious if you can buy a hf or si dx is to much work..and its more money really not worth it... i know</TD></TR></TABLE>
I dont know about where you live but si and hf are very hard to find..Dx's are every damn where....and its not that hard to do the mpfi wiring,,you're really only adding and swapping around a couple of wires..And then get some plugs from a junkyard..
