Where to unplug oxygen sensor on 95 gsr?
Old Apr 13, 2006 | 05:23 PM
cosmokramer's Avatar
Default Where to unplug oxygen sensor on 95 gsr?
alright...so im having this idle problem and have replaced almost everything ignition related. Well people have been telling me that it may be the oxygen sensor. I tried searching on how to unplug it to see if there is a change, but found nothing. So my question is does anybody know where to unplug the oxygen sensor from the engine compartment? Remember this is for an obd-1 integra, thanks!
Old Apr 13, 2006 | 05:34 PM
Promina's Avatar
Default Re: Where to unplug oxygen sensor on 95 gsr? (cosmokramer)
The O2 sensor is screwed into the header (if you have one) right before the cat converter. Just use a 17mm (I think) wrench to get it loose. Then wires run up to the harness that you can reach from under the car while you're loosing the O2 from the header and that can be disconnected. Once you've done that you have the male side connector attached to the O2. With mine the green wire (if I remember correctly) came out of the harness.
Old Apr 13, 2006 | 06:35 PM
blacK_Dc4's Avatar
Default Re: Where to unplug oxygen sensor on 95 gsr? (Promina)
i think on a 95 gsr its actually on the cat
Old Apr 13, 2006 | 07:43 PM
blkb18's Avatar
i believe you unplug it behind the radio/center console.
Old Apr 13, 2006 | 09:19 PM
Default Re: Where to unplug oxygen sensor on 95 gsr? (blkb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">i believe you unplug it behind the radio/center console.</TD></TR></TABLE>
really?? that doesnt sound right?
Old Apr 13, 2006 | 09:46 PM
gsr dood's Avatar
its on the downpipe on the header....right b4 the cat. u can reach it from behind the intake manifold....its a gray 4 pin clip
Old Apr 13, 2006 | 10:24 PM
LostGsr's Avatar
Default Re: Where to unplug oxygen sensor on 95 gsr? (gsr dood)
It's on the cat converter. There is only one. I'm positive on this because I changed mine before on a 94 Gsr. If you look at the pic, it's number 25.
Old Apr 13, 2006 | 10:29 PM
crxnj's Avatar
Default Re: Where to unplug oxygen sensor on 95 gsr? (LostGsr)
I use a 7/8 wrench to remove them..
Sonic89
Mar 1, 2013 10:46 PM
RboYi
Feb 15, 2005 04:59 PM
jdmxxdc2
Jan 13, 2005 08:17 PM
yldstyleviet
Jul 31, 2004 06:04 PM
gsrvx
Jun 5, 2002 05:05 AM
